iFixit 4 mm Screwdriver Bit
$2.99
$2.99
We'll send a message when the product is back in stock.
Black Friday
Broken doesn't stand a chance.
Product Details
Features
Features
A bit on Bits
  • Supplement your collection or replace lost bits.
  • These bits are made of high quality, nickel-plated CRV Steel
  • Many of these bits are available in iFixit's very own 64 Bit Driver Kit and Universal Bit Kit.
  • If you are looking for a fancy driver handle to use with your new bits, check out our 64 Bit Driver Handle.
Repair Stories
User avatar
My Problem
Broken Screens or other broken parts
My Fix
well i fix all kinds of phones a lot of iphones and i lost 2 of my bits so i did not know what to do i contacted ifixit and they just happen to sell just the bits so i got 2 of them and love fixing phones im glad they had the bits i need
My Advice
you need to order bits if y . . .
User avatar
My Problem
The battery was old and had gone through many cycles. It was not holding charge like it used to and would often require charging throughout the day.
My Fix
The repair went really well. The instructions were easy to follow as well as the plethora of resources on ifixit as well as youtube. The only annoying p . . .
User avatar
My Problem
Battery would not hold a charge for very long.
My Fix
Very well. I watched a video online and it explained exactly how to change the battery. The kit had everything I needed and it was reasonably priced.
My Advice
If you have a phone battery that won't hold a charge, buy this kit. It has everything you need and you . . .
User avatar
My Problem
Battery needed servicing. I was still running the original battery, but mainly on the charger 24/7.
My Fix
Followed the guide and the replacement was very easy.
My Advice
You will need a Tri-wing screwdriver. Luckily I had a frend that had one. If not for him, I would have had to delay the replacement until I foun . . .
User avatar
My Problem
My PS4 fan sounded like a jet engine.
My Fix
The repair went good.
My Advice
I don't have any advice.
User avatar
My Problem
My iPhone 4 battery was bad.
My Fix
Extremely easy!! All went as expected!
My Advice
Don't be intimidated! It's not difficult for anyone with basic mechanical skills.
User avatar
My Problem
I had a bad battery
My Fix
Quick and easy instructions - step by step
My Advice
buy the whole kit (battery and tools) for convenience.
User avatar
My Problem
The original battery was so low in "health" that it began shutting the computer off sporadically at charge levels lower than 50% - the computer was no longer reliable unless it was powered through the AC adapter.
My Fix
Your battery worked very well, starting off at around 30% charge and showing 99% health . . .
User avatar
My Problem
I bought my iMac with only the platter drive because the SSD options were so expensive. After dealing with the slow drive for a while, I found a 256 gb PCIe hard drive on eBay.
My Fix
The guide was spot on. The only hard part of this repair is the screen removal. The directions are clear though, and the rem . . .
User avatar
My Problem
Cracked Screen
My Fix
Isckack didnt stick because of a Tag that was already on the Iphone
My Advice
Buy the Nat
Show more
