Tri-point Y1 Screwdriver
This is just a 4 mm bit! In order to properly turn this bit, you'll also need a 4 mm screwdriver, or an adapter to work in a 1/4" screwdriver.
$3.99
$3.99
We'll send a message when the product is back in stock.
New Battery = Faster iPhone
Fix Kits starting at $16.99
Product Details
Features
Features
The tool you need to overcome security tri-wing screws.
  • Frequently used to deny users access to device internals, getting past is simple with the right tool.
  • Sturdy precision driver with a solid metal shaft, rubberized plastic handle, and spinning top.
  • Fits fasteners found on some Apple laptop batteries that use Apple Tool 922-8991.
  • Fixed-handle drivers make a great complement to a 64 Bit Driver Kit.
  • Upgrade to pro for an ESD safe professional-grade driver.
Repair Stories
User avatar
John's Story Photo #1174489
My Problem
My brother spilled coffee on his wife's 13" MacBook Pro...two years ago! They've just let it sit because they thought it would be too expensive to repair.
My Fix
SUPER easy. The guide was thorough and easy to follow. The only hitch was that after I replaced the logic board, I realized that 1. The battery wa . . .
User avatar
My Problem
Needed a good tool to remove the battery screws.
The tools that shipped with my amazon battery replacement were not good. They started to strip the screws. After several tries I stopped. However, I remembered that I ordered a memory upgrade kit with a great Mac tool from iFixit several years ago. T . . .
User avatar
My Problem
My old GameCube controllers had never been cleaned in the 14 or so years I've owned them. Decided to finally do something about it after seeing a video.
My Fix
It went surprisingly well, heh. I was afraid of frying the circuit boards both times.
My Advice
Definitely come to this site for specifics on how to fix whatev . . .
User avatar
My Problem
The MacBook Pro battery over heated and expanded within the laptop. It caused multiple restarts and other issues.
My Fix
The repair was easy with the assistants of the online tutorials. The end result was a working laptop.
My Advice
Trust yourself and rely on help from the pros at iFixit
User avatar
My Problem
Dead battery, it won't charge.
My Fix
It went pretty smoothly
My Advice
Be careful disconnecting the battery
User avatar
My Problem
One drop of water from condensation from a glass of lemonade, and no one makes a silicone guard for this?
My Fix
Wow, that was even easier than it looked. The instructions here were clear and correct. They made the job a snap. Every repair/upgrade I've ever tried was right here. I love this site. %#*@ Apple . . .
User avatar
My Problem
Original battery would not last 45 minutes of usage.
My Fix
Fairly easy
My Advice
Make sure you are careful with the tiny screws. They are very small.
User avatar
My Problem
As I was finishing up installing a new SSD drive into my son's 2012 MacBook Pro, I noticed that I was not able to log in to his iCloud account because the number 1-9 keys would not work. I had to connect a USB keyboard and troubleshoot. Sure enough, those keys were dead. In my search for a solution, . . .
User avatar
My Problem
needed a replacement battery
My Fix
it went great, thanks to your instructions!
My Advice
Luckily I live close to the US border, since the battery was not allowed to be shipped to CA
Your rep recommended I bring my computer with me and install in the US. Great advice!!!! Thank you!
User avatar
My Problem
bloated battery, the laptop didnt go to sleep when I closed the lid.
My Fix
battery replacement went well without any problems, too easy!
My Advice
make sure you have the Y1 screwdriver
Show more
