Product Details
Description
Welcome the Essential Care Bundle including the iFixit Essential Electronics Toolkit with the perfect selection of the most important tools needed for various electronic repairs, and the Magnetic Project Mat to keep your screws and small components safely organised. On top, you get 220 ml of the iFixit Screen Saver to keep your screens neat, our new multifunctional iFixit Tension Belt and a magnetic Bottle Opener.
The Essential Electronics Toolkit
Someday, maybe even today, your electronic device will let you down. Cracked screens and worn-out batteries can make your digital life aggravating. But you’re closer to a working device than you think, you just need the right tools. Enter our Essential Electronics Toolkit: It contains all the necessary tools for most electronic repairs while staying nice and compact.
Take charge of your own repair
We picked the perfect tools to safely open smartphones, laptops, small appliances, and so much more. The kit contains 16 precision bits (including Pentalobe and Tri-point) made from S2 steel as well as tools to help you get a grip on even the smallest components. We packed everything into a handy magnetized case with a lid that doubles as a built-in sorting tray for screws and small components.
Kit contents
- Opening tools to safely open high-tech devices
- Magnetic bit driver with 16 precision bits
- Tools for gripping and holding even the smallest components
- Compact, sturdy ABS plastic case with a built-in sorting tray lid
The Magnetic Project Mat
Especially when working on a smartphone or a laptop, one false movement during your repair can send all the numerous tiny screws and components of your device flying. If you’re lucky you can pick them up off the surface of your workbench, however you’ll be in a bad fix if they fall on the floor.
Everything securely held in place
To avoid freaking out over lost screws we recommend our Magnetic Project Mat. It measures 20 x 25 cm and allows you to keep your screws and small components safely organised exactly where you put them. You can jot down notes directly on the dry-erase surface to remember details about a particular component or guide step.
It’ll make your next repair project that much easier. All components stay magnetically put and organised and reassembly is up to 40% faster while preventing errors.
Kit Contents
- Essential Electronics Toolkit
- Magnetic Project Mat
- Screen Saver 220 ml
- Tension Belt
- Magnetic Bottle Opener
