iMac Intel 27" EMC No. 2309, 2374, 2390 or 2429 Power Supply
  • iMac Intel 27" EMC No. 2309, 2374, 2390 or 2429 Power Supply
$149.99
$149.99
We'll send a message when the product is back in stock.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Product Details
Description
Description
Replace a broken or damaged power supply for your iMac 27" Intel (Late 2009/Mid 2010) with this part. This part is compatible with all 27" iMacs with EMC No. 2309, 2374, 2390 or 2429.
Install Video
Compatibility
iMac Intel 27" EMC 2309 and 2374
2.66 GHz (Late 2009)
2.8 GHz (Late 2009)
3.06 GHz (Late 2009)
3.33 GHz (Late 2009)
iMac Intel 27" EMC 2390
2.8 GHz (Mid 2010)
2.93 GHz (Mid 2010)
3.2 GHz (Mid 2010)
3.6 GHz (Mid 2010)
iMac Intel 27" EMC 2429
2.7 GHz (Mid 2011)
3.1 GHz (Mid 2011)
3.4 GHz (Mid 2011)
Repair Stories
User avatar
Brandon Dusseau's Story Photo #779686
Brandon Dusseau's Story Photo #779688
Brandon Dusseau's Story Photo #779687
My Problem
The power supply was buzzing.
My Fix
The repair was super easy and straightforward. It helped that I had taken apart an iMac before and so I already knew the procedure for removing the LCD.
My Advice
It helps to unscrew the power supply first to make it easier to reach the locking clip underneath for the power distrib . . .
User avatar
nibbles's Story Photo #1021946
My Problem
A power cut during a rain storm occurred, and immediately the power tried to come back on five times over 10 seconds. Those brown outs and surges fried my 27" iMac late 2009 EMC 2374, even though it was connected to a cheap Belkin surge protector. All my other sensitive electronics connected to Pa . . .
User avatar
My Problem
No Power.
My Fix
Repair went smoothly as shown in the tutorial video and step by step instructions on ifixit site.
My Advice
I purchased the toolkit which was perfect for the job. I was worried I only had one suction cup, but the glass front easily pulled away from the frame by using only one suction cup. Be careful d . . .
User avatar
My Problem
Bad power supply in customer's 27" iMac. Wanted to make sure I got a good power supply, so I bought from ifixit.
My Fix
Swapping out supplies was pretty quick. Took more time screwing in LCD screws because of magnets than it did swapping power supplies. Thanks
My Advice
I always put the glass front in a clean plastic . . .
User avatar
My Problem
Power Outage.
My Fix
The repair was painless.
My Advice
Power protection in a turn-of-the-century home is really important.
User avatar
My Problem
Wife's iMac failed to start up one morning. Despite its age (2010), the iMac was perfectly suited for the wife's browsing and word processing needs, so it made sense to try to determine the cause and repair it before buying another iMac. First stop: iFixit.com.
My Fix
The repair went very well. Before buyi . . .
User avatar
My Problem
PSU had buzzing noise and was failing.
My Fix
Very well! This is not the first time I had opened up my iMac. Using iFixit guides are the way to go!
My Advice
Nothing to add, just follow the guide.
User avatar
My Problem
The power supply on our mid-2011 27" iMac died. The only location we could find a replacement was from iFixit in California. We live in Ontario Canada, and tax deadline was almost upon us, which meant we didn't have that much time to get our computer back up and running. Four days, to be exact. . . .
User avatar
My Problem
My mid-2011 iMac was making a buzzing sound; quiet if the LCD screen was off (screensaver) but louder and annoying when the machine was active.
I finally lost patience, and a brief search on the web indicated that the PSU would be the culprit.
It's normally left switched on 24/7; I powered it off la . . .
User avatar
My Problem
My wonderful 2010 27 inch iMac would not power on
My Fix
An easy search on a possible problem led me to I fixit and YouTube videos. All I had to order was the correct power supply for my emc and suction cups and was ready to dig in to it. Just as the YouTube video sowed the repair was easy
My Advice
Recommend ifuxit f . . .
Show more
