iMac Intel 27" (2012-2017) Adhesive Strips
  • iMac Intel 27" (2012-2017) Adhesive Strips / Fix Kit
  • iMac Intel 27" (2012-2017) Adhesive Strips / Part Only
$19.99
$19.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Adhesive Strips for Every Repair
  • This complete set of replacement adhesive strips is specifically cut to fit 27" iMacs from Late 2012 to 2017 and the 2017 iMac Pro.
  • The individual adhesive strips are labeled to indicate their correct location as shown in the replacement guides.
  • The kit includes one iMac Opening Tool.
The unique design of the 27" iMac requires the replacement of the adhesive strips whenever the display assembly is removed. Fortunately, these adhesive strips are actually a foam tape, easily cut with an iMac Opening Wheel. Unfortunately, the display has to be removed every time anything needs to be replaced or upgraded inside the machine.
Compatibility
iMac 27" 2017
EMC 3070 3.4 GHz
EMC 3070 3.5 GHz
EMC 3070 3.8 GHz
EMC 3070 4.2 GHz
iMac Intel 27" EMC 2546
2.9 GHz (Late 2012)
3.2 GHz (Late 2012)
3.4 GHz (Late 2012)
iMac Intel 27" EMC 2639
3.2 GHz (Late 2013)
3.4 GHz (Late 2013)
3.5 GHz (Late 2013)
iMac Intel 27" Retina 5k Display
EMC 2806 3.3 GHz (Mid 2015)
EMC 2806 3.5 GHz (Late 2014)
EMC 2806 4.0 GHz (Late 2014)
EMC 2834 3.2 GHz (Late 2015)
EMC 2834 3.3 GHz (Late 2015)
EMC 2834 4.0 GHz (Late 2015)
iMac Pro
EMC 3144 2.3 GHz (Late 2017)
EMC 3144 2.5 GHz (Late 2017)
EMC 3144 3.0 GHz (Late 2017)
EMC 3144 3.2 GHz (Late 2017)
Show 2 more devices
Repair Stories
User avatar
Rodney Stanton's Story Photo #1291271
Rodney Stanton's Story Photo #1291262
Rodney Stanton's Story Photo #1291269
My Problem
Computer lost power, wouldn't restart.
My Fix
Followed the iFixit pictorial guide. Everything went well and the instructions were accurate. The comment someone made about reinstalling the display unit was very helpful. Leave the side and top adhesive tape pull strips on until the two display cables are co . . .
User avatar
wilsonn's Story Photo #1368778
My Problem
Bad hard drive
My Fix
Still in progress waiting for replacement hard drive.
My Advice
Not all hard drives support SMART standard for reporting drive temp. Crossing my fingers I don’t need the additional adapter.
User avatar
Robin Spoerl's Story Photo #957962
My Problem
Upgraded hard drive to SSD for more speed.
My Fix
Repair went great! I was a little nervous removing the entire glass front of the iMac, but the guide made it easy to take off and put back on with new adhesive strips.
My Advice
Make sure you are familiar with the entire procedure before diving in.
User avatar
My Problem
The Seagate drive failed. (shocking, I know)
My Fix
Replaced the drive with a samsung SSD. The guide on ifixit was so helpful. I mean, really, really, you cant believe how helpful it was. Its like space ships that hang in the air the same way that bricks dont.
My Advice
SSD took some thinking to mount. Used a modified . . .
User avatar
My Problem
I was looking for better speed from iMac by the addition of an SSD and more RAM.
My Fix
The upgrade was pretty straight forward following the iFixit and youtube examples. I bought the iFixit adheasive tape kit with pizza cutter, spudger, plastic credit cards, heat sensor for the iMac (OCW) and a mounting b . . .
User avatar
My Problem
Thought the hard drive was crashing, computer freezing.
My Fix
Got the kit on time, but before the kit came, I did a reinstall of OS X on top of the old install. That fixed the issues.
My Advice
Sometimes a teardown is not needed, but so glad this community and online store exists for our repair needs.
User avatar
My Problem
Ich hatte zu wenig Speicherpatz und wollte eine zusätzliche SSD nachrüsten. Fusion-Drive war nicht vorhanden und daher auch kein SATA Kabel. SATA-Kabel bestellt und die Klebestreifen für das Display dazu.
My Fix
Anhand der Anleitungen absolut einfach. Man sollte aber UNBEDINGT nicht nur die Bilder anscha . . .
User avatar
My Problem
The HDD was slow
My Fix
Just fine, everything was smooth thanks to the ifixit.com guides and kit
My Advice
Make sure you don´t leave a gap at the bottom of the glass when sticking back the display
User avatar
My Problem
The stand on the 27 inch iMac just snaps all of a sudden and your iMac doesn't stand up properly.
See detail of the problem on: https://www.change.org/p/apple-recall-27...
My Fix
The repair was successful. See attached fotos
My Advice
In youtube I see the movies from ifixit.
User avatar
My Problem
The screen of our 27" iMac had been smashed. We sourced the fixing kit for the new screen from iFixIT.
My Fix
The kit worked brilliantly. All the parts were clearly labelled and were easy to use.
My Advice
Don't worry about doing the repair.
Show more
