iMac Intel 27" (EMC 2546, 2639, 2806) Adhesive Strips
$19.95
$19.95
We'll send a message when the product is back in stock.
Product Details
Features
Features
Adhesive Strips for Every Repair
  • This complete set of replacement adhesive strips is specifically cut to fit 27" iMacs from Late 2012 to Mid 2015.
  • The individual adhesive strips are labeled to indicate their correct location as shown in the replacement guides.
  • The kit includes one iMac Opening Tool.
The unique design of the 27" iMac requires the replacement of the adhesive strips whenever the display assembly is removed. Fortunately, these adhesive strips are actually a foam tape, easily cut with an iMac Opening Wheel. Unfortunately, the display has to be removed every time anything needs to be replaced or upgraded inside the machine.
Compatibility
iMac Intel 27" EMC 2546
2.9 GHz (Core i5, Late 2012)
3.2 GHz (Core i5, Late 2012)
3.4 GHz (Core i7, Late 2012)
iMac Intel 27" EMC 2639
3.2 GHz (Core i5, Late 2013)
3.4 GHz (Core i5, Late 2013)
3.5 GHz (Core i7, Late 2013)
iMac Intel 27" Retina 5K Display
3.3 GHz (Mid 2015)
3.5 GHz (Late 2014)
4.0 GHz (Late 2014)
Show 0 more devices
Repair Stories
User avatar
Ahmed Lotfy's Story Photo #738396
Ahmed Lotfy's Story Photo #738398
Ahmed Lotfy's Story Photo #738401
My Problem
To replace my 2639 iMac (27" late 2013) HDD with Samsung 850 PRO SSD
My Fix
It went smooth, thanks to iFixit guides, videos, and tools
My Advice
Take your time to plan and prepare for it, handle the screen with extra care, no need to completely remove the left speaker if you plan to replace the HDD; only moving it a l . . .
User avatar
Robin Spoerl's Story Photo #957962
User avatar
My Problem
No problem, only self install 0,35$/GB common ssd Instead of 3 times the price of Apple's ssd...
My Fix
Good. ifixit video tutorial + adhesive parts make it easy
My Advice
Carefully remove the bottom Edge adhesive. Don't use a cutter to cut it , Risk of scratching the back of the bottom glass panel edge , (visible on . . .
User avatar
User avatar
User avatar
User avatar
User avatar
My Problem
Ich hatte zu wenig Speicherpatz und wollte eine zusätzliche SSD nachrüsten. Fusion-Drive war nicht vorhanden und daher auch kein SATA Kabel. SATA-Kabel bestellt und die Klebestreifen für das Display dazu.
My Fix
Anhand der Anleitungen absolut einfach. Man sollte aber UNBEDINGT nicht nur die Bilder anscha . . .
User avatar
My Problem
I was looking for better speed from iMac by the addition of an SSD and more RAM.
My Fix
The upgrade was pretty straight forward following the iFixit and youtube examples. I bought the iFixit adheasive tape kit with pizza cutter, spudger, plastic credit cards, heat sensor for the iMac (OCW) and a mounting b . . .
User avatar
Show more
