PC3L-12800 4 GB RAM Chip
  • PC3L-12800 4 GB RAM Chip
$34.99
$34.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Replace your old, damaged, or otherwise underwhelming RAM configuration in your computer with this part.
Note
That "Warranty Void if Removed" sticker is wrong. Feel free to peel that sucker off, we'll still honor our warranty. Our RAM supplier made a mistake in printing, and we're fixing it in our next order of memory.
Compatibility
iMac Intel 21.5" EMC 2544
2.7 GHz (Late 2012)
2.9 GHz (Late 2012)
3.1 GHz (Late 2012)
iMac Intel 21.5" EMC 2545
3.3 GHz (Early 2013 Edu)
iMac Intel 21.5" EMC 2638
EMC 2638 2.7 GHz (Late 2013)
EMC 2742 2.9 GHz (Late 2013)
EMC 2742 3.1 GHz (Late 2013)
iMac Intel 27" EMC 2546
2.9 GHz (Late 2012)
3.2 GHz (Late 2012)
3.4 GHz (Late 2012)
iMac Intel 27" EMC 2639
3.2 GHz (Late 2013)
3.4 GHz (Late 2013)
3.5 GHz (Late 2013)
iMac Intel 27" Retina 5k Display
EMC 2806 3.3 GHz (Mid 2015)
EMC 2806 3.5 GHz (Late 2014)
EMC 2806 4.0 GHz (Late 2014)
Mac Mini Late 2012
2.3 GHz (Quad i7)
2.5 GHz (Dual i5)
2.6 GHz (Quad i7)
MacBook Pro 13" Unibody Mid 2012
2.5 GHz
2.9 GHz
MacBook Pro 15" Unibody Mid 2012
2.3 GHz
2.6 GHz
2.7 GHz
Show 6 more devices
Repair Stories
User avatar
amyharri's Story Photo #572641
My Problem
My mid-2012 unibody MacBook Pro was being throttled, no more RAM, and before throwing it out the window thought I'd try adding the RAM.
My Fix
The repair went smoothly - and I'd never opened my laptop before so wasn't sure. But the guide was clear and it went great.
My Advice
I ordered 2 Phillips head screwdrivers bec . . .
User avatar
My Problem
My old MacBook Pro's battery was swelling out of the case and was a bit outdated.
My Fix
Replaced the swollen battery and pushed the aluminum back to its intended shape.
Kicked the RAM up to 8gb
Replaced hard drive with 1TB Hybrid drive
The whole process was quick and painless. The guides offered on this . . .
User avatar
My Problem
Needed more ram for certain programs
My Fix
I used my Ifixit tools: #00 Phillips screwdriver, spudger and additional 4MB ram. Everything went well and no disaster. The Apple hardware test confirmed it.
My Advice
Using the Ifixit instructions and the right tools anyone can replace ram. Take your time, organize your . . .
User avatar
My Problem
I wanted more memory for multitasking purposes.
My Fix
The repair was quite easy following the step by step instructions.
My Advice
Get the pro toolkit.
User avatar
My Problem
My mid 2012 refurbished MBP was downright pokey, constant beach ball of death. It had only the stock 4 gigs of ram.
My Fix
I installed 2- 4 gig sticks with nary a hiccup. The guide was spot on (in some ways superior to Apple's own instructions) but did omit the suggestion to discharge any static charge by t . . .
User avatar
My Problem
My friends Mid 2012 was as fast as a turtle. He was considering changing it, however budget was a problem, so I recomended upgrading two components that may be slowing the performance: hard drive (always at full capacity) and RAM.
My Fix
After receiving the products and following iFixit guides, part exchang . . .
User avatar
My Problem
The system was moderately sluggish on memory intensive apps.
My Fix
I replaced the 2 2GB simms with 2 4GB simms. No tools were required, and it worked fine the first time.
My Advice
I would recommend this repair. The only down side is what to do with the old memory sticks?
User avatar
My Problem
To increase speed of laptop
My Fix
Very Easy
My Advice
Use ifixit.com
User avatar
My Problem
Brand new late 2012 Mini. Wanted more out of life. So I decided a 128 Gb SSD and a 1 Tb hybrid drive and some more RAM.
This turned out just great. Except that I wasn't sent a logic board removal tool.
My Fix
Only problem with the repair is that the Dual Drive Kit did not include the Mac Mini logic boar . . .
User avatar
My Problem
needed more ram and it was smooth... except for the screw driver
My Fix
the ram was great, and luckily i had my own screw driver the one here did not work very well for the screws in the laptop (started to strip them).
My Advice
the ram and ifixit (shipping etc) was phenomenal. if you dont need the screw driver, dont . . .
Show more
