MacBook Air 11" (2013-2015) 13" (2013-2017) MacBook Pro Retina 13" and 15" (2015) SSD
  • MacBook Air 11" (2013-2015) 13" (2013-2017) MacBook Pro Retina 13" and 15" (2015) SSD
655-1802, 661-7456, 661-7458, 655-1816, 661-7457
$199.99
$199.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Replace your SSD today!
All drives have been erased and do not have OS X installed.
Apple Part numbers are specific to solid-state drive capacity, refer to products options for details.
Compatibility
MacBook Air 11" Early 2014
1.4 GHz
1.7 GHz
MacBook Air 11" Early 2015
1.6 GHz
2.2 GHz
MacBook Air 11" Mid 2013
1.3 GHz
1.7 GHz
MacBook Air 13" Early 2014
1.4 GHz
1.7 GHz
MacBook Air 13" Early 2015
1.6 GHz
2.2 GHz
MacBook Air 13" Early 2017
1.8 GHz
2.2 GHz
MacBook Air 13" Mid 2013
1.3 GHz
1.7 GHz
MacBook Pro 13" Retina Display Early 2015
2.7 GHz
2.9 GHz
3.1 GHz
MacBook Pro 15" Retina Display Mid 2015
2.2 GHz (Integrated Graphics)
2.5 GHz (Dual Graphics)
2.5 GHz (Integrated Graphics)
2.8 GHz (Dual Graphics)
2.8 GHz (Integrated Graphics)
Show 6 more devices
Repair Stories
michael's Story Photo #655044
My Problem
to less space on internal 500GB SSD because of my software from native instruments (Maschine, Komplete Ultimate) and my software development tools (java, liferay)
My Fix
without any problems within 10 Minutes
My Advice
I ordered a used drive. It was an original apple device and works without any problems.
My Problem
I went through the guide from iFixit and repaired it by myself.
My Fix
It was good and my machine is working fine.
My Advice
From iFixit.
My Problem
no problems
My Fix
easy
My Advice
no peoblems
My Problem
The MacBook Air came with a 120 GB SSD, which was not nearly enough storage for our use.
My Fix
The upgrade to a 500 GB SSD was stress free after buying the screwdrivers that were needed from iFixit. And the instructions on the iFixit Web site were great. It made things very uncomplicated, and fast.
My Advice
Everythi . . .
My Problem
250 GB SSD crashed after upgrade to Yosemite. Using my limited diagnostic skills I found that the problem was related to an error with the partition map (it couldn't be read). I tried everything I could to format and partition with no luck.
My Fix
I upgraded to a 500 GB SSD. It took 10 minutes to switch out . . .
My Problem
All started with an awful message from the tiny guy pedaling inside my MacBook Air 11: "On strike until getting more space to work" (he's French, like me, very keen to grumble...). My machine worked wonderfully but could not store an Nth of a picture from my iPhone for example...
My Fix
I received all the m . . .
My Problem
I was running out of space on my macbook and the used SSD finally became available. Really needed the extra space for bootcamp
My Fix
The repair was easy as long as you have the right tools
My Advice
Ensure you have all the tools listed prior to starting. If you don't have the Pentlobe Screw Driver, you should buy one . . .
My Problem
An certified Apple repair centre told me my mainboard was gone and it was cheaper to replace. I had a feeling they were wrong so I checked it out with Apple Software Diagnostics
My Fix
Very simple and quick. MacBook is back and running and wife is happy.
My Advice
Don't always listen to certified Apple Repair shops. . . .
My Problem
The space on the 256 GB SSD in my mid 2013 MacBook Air 11" was getting narrow.
My Fix
I ordered on a Sunday, the package arrived on Wednesday - in Germany!! Having the right tools, the exchange was done in two minutes. Of course the data transfer from the time machine backup took significantly longer, two h . . .
My Problem
upgrade from 128GB sad
My Fix
repair very easy within 10mn.
My Advice
follow ifixit guide, well done
Show more
