MacBook Upper Case Cable
$24.95
$24.95
We'll send a message when the product is back in stock.
Product Details
Features
Features
Are your logic board and upper case not talking?
Replace a damaged upper case cable and restore function to your upper case again. This cable transmits that data from the power button, keyboard, and trackpad to your MacBook's logic board
Note: There are two different types of cables for the MacBook. The older version uses a brown Foxconn cable and the newer version uses a silver cable. The cable must be replaced with a similar cable or your upper case will not function properly.
Compatibility
MacBook Core 2 Duo
1.83 GHz (Core 2 Duo)
2 GHz (C2D, Late 2006)
2 GHz (C2D, Mid 2007)
2 GHz (Early 2009)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.16 GHz (Core 2 Duo)
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz (Core Duo)
2 GHz (Core Duo)
Repair Stories
User avatar
paulxpac's Story Photo #230145
My Problem
My MacBook (Model 1181) is in pristine condition, so getting a new one seemed wasteful. After doing an internet search on possible causes of intermittent track pad and keyboard failure, I found it to be a consistent problem with these models. I ran thru the prescribe checks and decided to change out . . .
User avatar
lxtc's Story Photo #225913
My Problem
My upper case cable didn't like disassemblies much so I had to get a more cooperative one. / Excédé par des démontages intempestifs mon câble de clavier a décidé de cesser toute collaboration avec moi, d'où remplacement par un collègue au caractère plus docile.
My Fix
Thanks to the guide, all went . . .
User avatar
User avatar
My Problem
Trackpad and keyboard continuously seen as being disconnected and reconnected by USB daemon. Internet was unanimous that issue was USB upper case cable.
My Fix
Replaced the part (and replaced a few stripped screws too)... but issue persists. The problem : faulty upper ase cover.
My Advice
When your mac starts going ha . . .
User avatar
My Problem
For some time I had problems with the computer recognizing my keyboard and touchpad and one day it just stopped turning on, so i opened the computer and i saw that the MacBook upper case cable was broken in one place probably because of many times of opening and closing the computer, 7 years old com . . .
User avatar
User avatar
My Problem
I had opened up my MacBook to replace my optical drive with a SATA cable so that I could connect my external SATA drive internally and get the speeds that I need. After opening the case so many times, I guess the cable just broke. This being the case, my trackpad and internal keyboard no longer func . . .
User avatar
My Problem
I was upgrading a computer for a kid down the street. The original plan was to upgrade his hard drive and RAM. Once we accomplished that we decided to upgrade his OS as well. That's where the "scope creep" began. His DVD player was kapoot and we couldn't get the Snow Leopard DVD out of his machi . . .
User avatar
My Problem
I started out having to replace the Dvd drive as it was not working. I was putting everything back when I broke the keyboard ribbon cable.
My Fix
I used the ifixit repair guides and it went smoothly. They are fantastic! My MacBook is working fine with a brand new dvd superdrive. The keyboard and the b . . .
User avatar
My Problem
I couldn't start the laptop, so I had to fix it.
My Fix
It went perfectly, I've received the parts in just five days, by regular mail. Considering that I live in Spain. That was very fast.
My Advice
Just be very careful with the Mackbook Upper case and it should go fine, and that in the other end of the cable(the on . . .
Show more
