MacBook Unibody Model No. A1342 Lower Case
  • MacBook Unibody Model No. A1342 Lower Case
$149.99
$149.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Replace a broken or damaged lower case for your Model A1342 MacBook Unibody with this part.
Compatibility
Repair Stories
User avatar
gveldman's Story Photo #462277
My Problem
A few weeks ago the rubber coating released it self, caused by the heat, from the lowercase of our Macbook, end 2009 version. Because the Apple replacement program was not applied on this Macbook, I decided to repair it my self. The Macbook is in perfect state, including 4GB memory and running Yosem . . .
User avatar
My Problem
Rubberized on original back was coming off. Rubber stretched and buckled over time
My Fix
Easy, eight screws and done. Finding the correct back from other vendors was the greatest headache
My Advice
call Fixit first.
User avatar
My Problem
My partners late 2009 Macbook started to fall apart all at once. The rubberised bottom peeled off, the batter stopped holding a charge and the fan failed.
I replaced the laptop with a new macbook and kept the old one until it failed completely which was the day after it was replaced.
A year later . . .
User avatar
My Problem
Bottom was missing screws, and rubber was coming off the metal. Was not affecting operation of the laptop. More cosmetic than anything.
My Fix
Got the new bottom and screws in the mail a few days after I ordered them, removed the old bottom, and installed the new bottom within minutes. Very easy to do.
My Advice
N . . .
User avatar
My Problem
Heavy-duty processing warms up the underside of my MacBook, and eventually the rubber layer on the base-plate released itself from the metal where the heat is most intense and created a large bubble. The computer couldn't sit flat on a tabletop anymore, so a replacement base-plate was required.
My Fix
The n . . .
User avatar
My Problem
My wife's Macbook stopped charging. After a short troubleshooting I figured out that the Magsafe connector was at fault. Also, as the laptop was mostly used on soft covered surfaces, cooling was poor, causing some overheating of the lower case, hence causing bubbling of the non slippery rubberized s . . .
User avatar
My Problem
Because it was broken.
My Fix
10 min. Done.
My Advice
It's great. Never grab your chick and through it to the bed when the laptop is sitting there. The display screen may suffer.
User avatar
My Problem
The old case was coming apart and needed to be replaced.
My Fix
Very easy, just remove old case and replace with the new one.
My Advice
Having the right screwdriver made the job easier. Would recommend that first.
Show more
