MacBook Unibody Model No. A1278 Upper Case (Backlit)
  • MacBook Unibody Model No. A1278 Upper Case (Backlit)
$249.99
$249.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Replace a broken or damaged backlit upper case assembly for your Model A1278 MacBook Unibody with this part.
Note
Some 2 GHz A1278 MacBook logic boards do not have the necessary socket installed to accept the keyboard backlight ribbon cable attached to the upper case. The second and third pictures show logic boards with and without the socket installed, respectively. If your logic board does not have the backlight ribbon cable socket installed, the keyboard will work but the keys will not light up.
If your logic board does not have the socket installed to accept the keyboard backlight ribbon cable and you are installing a backlit upper case, simply tuck the keyboard backlight ribbon cable out of the way when you reinstall the logic board into the upper case.
Disclaimer
New option includes backlit keyboard, battery level indicator assembly, IR sensor, and battery connector cover. Used option includes backlit keyboard but does not' include battery level indicator assembly, IR sensor, or battery connector cover.
Compatibility
Repair Stories
User avatar
My Problem
I don't speak english, but it's easy to understand the ifixit's guide. ;)
Del succo ACE era caduto rovinosamente sulla tastiera rendendo il tasto shift sinistro in uno stato di perenne attivazione.
Essendo praticamente impossibile sostituire solo il tasto o solo la tastiera, ho ordinato un nuovo . . .
