MacBook Unibody Model No. A1278 MagSafe DC-In Board
  • MacBook Unibody Model No. A1278 MagSafe DC-In Board
  • 360°
360
$44.99
$44.99
We'll send a message when the product is back in stock.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Product Details
Description
Description
Replace a broken or damaged MagSafe DC-in board for your Model A1278 MacBook Unibody with this part. This part connects the AC wall adapter power to the logic board.
Disclaimer
This part is only for the MacBook Unibody model A1278. It will NOT work in a MacBook Pro model A1278. Identified by 820-2361-02 printed on the board.
Compatibility
Repair Stories
User avatar
Axel's Story Photo #232021
Axel's Story Photo #232024
Axel's Story Photo #232025
My Problem
My MacBook was actually having trouble to charge the battery and the LED on the plug of the MagSafe was switching on/off without any good reason. I made a "cross test" : I pluged my MagSafe Power Adaptor to another laptop and the LED was staying on. So the Adaptor was not the one to blame :).
The . . .
User avatar
My Problem
Due to the overheating issue, I cannot watch streaming because computer decrease performance when there is too much heat
My Fix
Thanks to the tutorial, the replacement of the board was very easy.
Unfortunately the repair did not fix my issue - I think that the power supply is faulty.
My Advice
Try with new power suppl . . .
User avatar
My Problem
The Macbook of my Wife suddenly switches off, with green light of Macsafe connector.
Also when charging, only short time charges, then switches to green.
When i took out Battery, Macbook won't start.
My Fix
1st replaced Battery by a new one. - but same thing.
Then i thought it might be the main board, t . . .
User avatar
My Problem
DC-In board had been slowly but surely failing over the course of two years. Finally got to the point where I'd spend 15 minutes fiddling with the MagSafe to get my MacBook to charge. Most of the times I'd just give up in frustration, curse, and storm off outside to the wallow in the overly fresh Ca . . .
User avatar
My Problem
Reason for fix - I believed that this part was defective in my MB. As I purchased used from a less than shimmering source, I wasn't sure what to expect. I was having significant battery drain when completely powered off (not in sleep mode) overnight. System also reported that power was connected, ev . . .
User avatar
My Problem
Could not charge or apply power.
My Fix
Went great!! works like a charm!!
My Advice
follow the guide on I fix it!!
User avatar
My Problem
I am currently deployed to Afghanistan, I have a 2008 late model Macbook that was not charging or having difficulty charging. I had to fiddle with the DC-In connection and get it at the precise angle to get it to charge. I bought a new MagSafe Power supply from the PX and it didn't seem to help. I . . .
User avatar
My Problem
My laptop didn't just suddenly stop charging. No, it would charge if I had the cable in JUST the right way... you know how it goes. After I bought a new cable and found the same problem, I knew it had to be the port. Angst and despair set in.
My Fix
It was a long and scary process. I've replaced the logic b . . .
Show more
