MacBook Unibody (A1342) Trackpad
  • MacBook Unibody (A1342) Trackpad
  • 360°
360
Includes 4 mounting screws, set screw, metal mounting bracket, and 4 bracket screws.
$79.99
$79.99
We'll send a message when the product is back in stock.
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Product Details
Description
Description
Replace a broken or damaged trackpad for your MacBook Unibody Model A1342 with this part. This assembly includes the trackpad cable. Please check the option description to determine what mounting hardware and screws are included with each option.
Compatibility
Repair Stories
User avatar
My Problem
The track pad went from not clicking to moving around sporadically while you tried to click on anything.
My Fix
It was very simple when following the directions.
My Advice
After installing the track pad dont screw on the bottom immediately. Turn on the computer and check the 'clickage'. You might have to tighten or lo . . .
User avatar
My Problem
I helped my niece purchase her first used computer. When it arrived the trackpad wouldn't click. Instead of sending it back for a refund and realizing we would lose the shipping to and from and then not have a computer, I decided to go ahead and replace it myself.
My Fix
Part was delivered in a timely manne . . .
User avatar
My Problem
Using ifixit repair guide I bought and installed a new trackpad.
My Fix
Following the guide It was easy and problem solver in 15 minutes.
My Advice
Ifixit, The right guide at The right place with the right parts!
User avatar
My Problem
Old and dead trackpad.
My Fix
Only took ten minutes!
My Advice
Works like new! Took me ten minutes to replace the trackpad.
Will order again from iFixit as they use quality parts.
User avatar
My Problem
My white unibody macbook was having problems with the trackpad. After days of searching the internet, trying software fixes, cleaning, checking battery, etc, nothing worked. I finally decided to go for it and buy a new replacement Trackpad with screws, the #00 Phillips Screwdriver, and the Y1 Tri- . . .
User avatar
My Problem
Trackpad clicker didn't work
My Fix
The instructions were very clear and replacement went easy.
My Advice
After installing the new trackpad the clicker still didn't work. I took it apart and noticed an adjustment screw that actuates the detent. I increased it and then it worked great. I didn't bother to try the old tr . . .
User avatar
My Problem
The battery swelled in the middle so much that it pushed the track pad up our of the computer.
My Fix
Trackpad replacement seemed at first not to work, new pad was also out of alignment, but shifting the strips that hold it in slightly solved the problem and the track pad aligned. Worked perfectly. Putting . . .
User avatar
My Problem
My trackpad lost it's clicking ability
My Fix
Replace with a brand new trackpad bought from www.ifixit.com
My Advice
Please don't rush with any of your repairs. That's what I got from my past and present experiences.
User avatar
My Problem
My son dropped his phone onto his trackpad and chipped the corner of it.
My Fix
We received the part and tool within a couple of days. I reviewed the online repair process and ten minutes later we were up and running again.
My Advice
I would definitely use Ifixit again and recommend the online tutorials. They are ea . . .
User avatar
My Problem
My MacBook track pad was acting up. Unable to click, not very responsive to touch.
My Fix
The repair process went smooth thanks for the useful detailed guide and all the tools and accessories provided by iFixit.com.
My Advice
If the track pad just not clickable (or having trouble clicking), just need to readjust the . . .
Show more
