MacBook Santa Rosa/Penryn Upper Case with Keyboard
  • MacBook Santa Rosa/Penryn Upper Case with Keyboard / White / New
$119.99
$119.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Replace a broken or damaged upper case for your 13.3" MacBook with this part (excluding MacBook Unibody and MacBook Air). This part includes the keyboard, palmrest area, trackpad, trackpad cable, and power button.
Note
This upper case has been tested and functions in all model A1181 MacBooks, including MacBooks that originally shipped with an upper case with a different function key layout. This upper case can be installed in these early model MacBooks as an upgrade, and all function keys will operate properly.
Compatibility
MacBook Core 2 Duo
1.83 GHz
2 GHz (Early 2009)
2 GHz (Late 2006)
2 GHz (Mid 2007)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.16 GHz
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz
2 GHz
Repair Stories
User avatar
My Problem
I was working at Starbucks when my friend Carlos saw me and came over to give me a hug. I knocked a whole bottle of Soylent on my keyboard. Eek.
My Fix
It took about two hours total. I was going extra slowly because I had not worked on a Macbook before. If I should need to do it again, god forbid, it could . . .
User avatar
My Problem
classic cracking in the display bezel and topcase palmrest. Felt like the Mac desirved to be refurbished after the fond college memories
My Fix
followed the online takeapart guide, was easy as 1 2 3
My Advice
make sure to retain the plastic fitting clips when removing the old front bezel frame, they are needed in ord . . .
User avatar
My Problem
era rotta
My Fix
bene grazie alle istruzioni
My Advice
conviene
User avatar
My Problem
Spilled iced tea all over my upper case and my front bezel was showing some age
My Fix
It went well thanks to the guides
My Advice
Diy
User avatar
My Problem
My 7 year old MacBook's keyboard stopped working with many of the keys. Went to the Apple Store. they said for this paticular computer, they did not have the part. Was going to put the MacBook to sleep for good, and decided to tackle changing the keyboard. note| I have zero experience with computer . . .
User avatar
My Problem
Bezel was cracked in assorted places.
The right and left arrow keys quit working.
The trackpad and select (long key below the trackpad) had issues.
My Fix
I followed the guides and used the plastic bag method to keep track of the screws, at each step I numbered the bag to the step in the instructions. I fou . . .
User avatar
My Problem
Right and Left arrow keys stopped working
The actuator key below the track pad was sticking.
The bezel was cosmetic .
Mac Store wanted almost $400.00 to do the Fix
My Fix
When I removed the screws with Fixit instructions The some of the screws were in the wrong holes. this unit had been fixed at a
"mac "re . . .
User avatar
My Problem
The letter 'A' came off of the keyboard and would not reseat. My granddaughter needed this MacBook for school.
My Fix
The repair could not have been easier due to the very detailed disassembly photos along with the text describing the size of each screw. Replacing the top case-keyboard took about an hour . . .
User avatar
My Problem
A of mine client dropped their iPhone 5 and shattered the glass / Another client brought me their MacBook since the display wouldn't show anything if it was opened all the way and only showed the desktop when less then half open.
My Fix
For the iPhone 5, it was smooth and easier then replacing the display o . . .
User avatar
My Problem
I killed the keyboard with coffee and coffee grounds. It was early morning. I was outside at my wobbly patio table with my MacBook open. I tried to press my coffee, lost the whole pot of morning coffee, and committed keyboard murder at the same time.
My Fix
I deconstructed the entire machine and cleaned it . . .
Show more
