Fix Your Stuff
Right to Repair
Store
MacBook Pro 17" Unibody (Early-Late 2011) Replacement Battery
  • MacBook Pro 17" Unibody (Early-Late 2011) Replacement Battery / Fix Kit
  • MacBook Pro 17" Unibody (Early-Late 2011) Replacement Battery / Part Only
  • 360°
360
$99.99
$99.99
We'll send a message when the product is back in stock.
OPEN ALL THE TABS
RAM Upgrade Kits for Mac
Shop Kits
Enough RAM
For All The Tabs
Shop Kits
Product Details
Description
Description
This MacBook Pro 17" Unibody (Early-Late 2011) replacement battery is what you need to bring your dead laptop back to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 12530 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
  • Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your laptop’s lifespan, extend it with this new replacement battery compatible with Early to Late 2011 MacBook Pro 17" Unibody. Factory-installed MacBook Pro batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Kit Contents
Kit Contents
Compatibility
Compatibility
  • MacBook Pro 17" Unibody A1297 Early 2011 to Late 2011
Specifications
Specifications
Model #:
A1383
Watt Hours:
95 Wh
Voltage:
10.95 V
Milliamp Hours:
13190 mAh
Manufacturer:
Aftermarket
Compatibility
A1297 (EMC 2352-1) 2.2 GHz (Early 2011)
A1297 (EMC 2352-1) 2.3 GHz (Early 2011)
A1297 (EMC 2564) 2.4 GHz (Late 2011)
A1297 (EMC 2564) 2.5 GHz (Late 2011)
Customer Reviews
