MacBook Pro 17" Unibody (Early 2009-Mid 2010) Replacement Battery
  • MacBook Pro 17" Unibody (Early 2009-Mid 2010) Replacement Battery / New / Fix Kit
  • MacBook Pro 17" Unibody (Early 2009-Mid 2010) Replacement Battery / New / Part Only
  • 360°
360
$89.99
$89.99
We'll send a message when the product is back in stock.
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Product Details
Description
Description
This Replacement Battery compatible with MacBook Unibody (Model No. A1342 Late 2009/Mid 2010) is what you need to bring your laptop back back to life. Our aftermarket replacement batteries lead the industry in quality and reliability—each is tested and guaranteed to have a capacity greater than 12530 mAh—so you know you're getting the best money can buy.
Kit Contents
Kit Contents
Note
Lithium ion battery shipping regulations limit the shipping methods for orders containing batteries. Domestic orders may only be shipped via Standard shipping. iFixit is not able to ship batteries internationally or outside the contiguous US at this time. iFixit Customer Support will contact you if your order needs to be modified after it is placed.
Warning
Lithium-ion batteries pose a fire hazard if they swell due to age or defect. Learn more about safe handling and proper disposal of all batteries.
Compatibility
2.53 GHz (Mid 2010)
2.66 GHz (Early 2009)
2.66 GHz (Mid 2010)
2.8 GHz (Mid 2009)
2.8 GHz (Mid 2010)
2.93 GHz (Early 2009)
3.06 GHz (Mid 2009)
Repair Stories
My Problem
The battery was almost 9 years old and only had 57% charge capacity left.
My Fix
The repair was very simple. I believe it took longer to restart the laptop then to do the replacement.
My Advice
Make sure to read, understand and follow the directions in the guide.
My Problem
2 problems: First, battery losing life, then computer could not communicate with hard drive.
My Fix
Went well. The drive cable was a bit of a challenge because of the need to bend it at sharp right angles to fit stair-step in upper case where it gets fastened with screws, but after several tries, got it to . . .
My Problem
Battery was completely dead
My Fix
Super easy and very helpful guide to understand and follow
My Advice
You guys do great work thanks!
My Problem
Original battery was swollen
My Fix
Nice and simple
My Advice
Be sure to read the guide. There was one connector I originally overlooked that the guide pointed out.
Have the right tools. The screws that hold the battery in place would be badly damaged and likely the screwdriver I used would be too.
My Problem
Electrical part which had a relative simple problem to fix.
My Fix
Very well - as expected.
My Advice
When unsuccessful finding the appropriate tool at the local hardware store, go to the internet - especially the iFixit website.
My Problem
No problem, only self install 0,35$/GB common ssd Instead of 3 times the price of Apple's ssd...
My Fix
Good. ifixit video tutorial + adhesive parts make it easy
My Advice
Carefully remove the bottom Edge adhesive. Don't use a cutter to cut it , Risk of scratching the back of the bottom glass panel edge , (visible on . . .
My Problem
Only my grandson knows
My Fix
Hasn't started yet-- gets parts Dec. 25
My Advice
Ask for recipients email
My Problem
Screen was broken and I decided to fix it instead of replacing the whole unit.
My Fix
We followed the instructions step by step and it went very well. The phillips screwdriver ended up not really working on the first set of screws but i had another that was better but other than that everything went really . . .
My Problem
have used ifixit site before and was very pleased with outcome
My Fix
the repair went smoothly; my trackpad repair came without the cable so i needed to swap that over so there should be a couple of pics on how to do that
My Advice
don't be afraid to tackle such a project; plenty of guides and tools available to do th . . .
My Problem
My trackpad had become extremely hard to click and took a lot of force to do any clicking. So, I decided to replace the pad and upgrade the RAM while I was inside the computer.
My Fix
The repair was simple and easy and took about 25 minutes to complete. I even did a lot of cleaning inside the computer while . . .
Show more
