MacBook Pro 17" (Model A1261) Left Fan
  • MacBook Pro 17" (Model A1261) Left Fan
$39.99
$39.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Replace a noisy or broken fan.
If your screen is facing you, this is the fan on the left side of the machine. Includes fan and surrounding metal bracket.
Looking for the Right Fan?
Compatibility
Repair Stories
User avatar
My Problem
Laptop was running really hot. Fan control utility showed left fan was not running. 0 RPM.
My Fix
Outstanding. Followed repair guide easily
My Advice
Add recommendation for cleaning dust from fan exit ports. Remove both fans and clean dust. Tooth picks and Q-tips worked
Add link in guide for removing and reconnec . . .
User avatar
My Problem
Fan was noisy
My Fix
Part came in when expected and was correct. Used the Ifixit guide to tear down and replace the fan which went with no issue. Did have an issue with the Mac's top case where the front inside screw attachment brackets spot welds failed (not happy with Apple's quality here), but everythi . . .
User avatar
My Problem
The right fan had become very loud.
My Fix
I first tried to just clean the fan blades, as others on the web have noted. But the blades are fragile and I managed to break one off while cleaning. Even though I was being quite careful.
So I bought a new fan. I decided to replace both fans as both were dirty . . .
User avatar
My Problem
Left fan was noisy enough to be heard from the next room.
My Fix
First try was on the previous weekend -- I used the guide to take out the noisy fan, disassembled it, cleaned it, and applied some lube. Put everything back together, fired it up, and there was blessed silence.
For ten minutes.
Ten min . . .
User avatar
My Problem
Funny thing. The sensors acted weird - it even wrote messages by itself.
My Fix
Same procedure as always - just follow the tutorial.
My Advice
After changing the iPhone display, the phone might not start up with just the backlight on. Don't panic, just do a forced reboot (Home + Power button until you see the apple)
User avatar
My Problem
Noisy fans in the MacBook Pro made using the laptop nearly impossible. The high pitch whiny rattle was loud and obnoxious at times and what Apple wanted to charge to fix it was like taking out a second mortgage. So when I found iFixit with guides on "how to" I thought why not?
My Fix
The guides didn't make . . .
User avatar
My Problem
Left fan was making loud grinding sound, so both fans replaced to avoid future problems with right fan
My Fix
Instructions were very good with easy step by step procedures.
My Advice
FOLLOW THE INSTRUCTIONS, make sure the i-sight cable and converter cables are properly connected before closing the case. Use something . . .
User avatar
My Problem
The MacBook was too warm!
My Fix
All OK! It was necessary about 8 housr of work (disassembly and re-assembly the MacBook)
My Advice
Show more
