MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable
  • MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable / New / With Bracket
  • MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable / New / Without Bracket
  • MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable / Used / With Bracket
  • MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable / Used / Without Bracket
  • 360°
360
$34.99
$34.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Replace your old or damaged Hard Drive Cable!
Compatibility
Repair Stories
My Problem
I tore the original cable replacing the hard drive.
My Fix
Very easy! Outside a little adhesive that was holding s portion of cable to the case body, the old cable came out nicely, and the new cable went right into place.
My Advice
Take your time! Just apply a little pressure as you remove the cable, and be sure to se . . .
My Problem
I purchased a 1tb Crucial SSD to replace the HDD in my MacBook Pro. After formatting the drive and using CC Cloner to clone it, I could boot to the SSD via USB, but not from the internal SATA connection. THE SSD was not even recognized when plugged into the internal SATA cable. I contacted Crucial w . . .
My Problem
My friend's Mac wouldn't start up since a full bottle of Tequila was spilt on it.
My Fix
First I had to clean the casing and motherboard with alcohol and coton swabs. I thought the HDD was dead so I tried another one but I couldn't see it in the disk management (I booted from a USB key I made with 10.9 inst . . .
