MacBook Pro 15" Unibody (Mid 2009) Hard Drive Cable
  • MacBook Pro 15" Unibody (Mid 2009) Hard Drive Cable
This used part has the IR sensor, indicator light and hard drive bracket attached.
Condition: Used
$39.99
$39.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Replace a torn or damaged MacBook Pro 15" Hard Drive Cable to restore hard drive functionality.
With this model of the MacBook, the hard drive cable has a bend at the point it passes over the optic drive. A failure in this part is not uncommon, due to the copper tracks on the cable breaking at this flex point. Apple fixed this problem in later versions of the cable, however the upgraded version will sometimes break as well.
One way of partially checking to see if the issue is your hard drive or your hard drive cable, is to externally connect the hard disk drive (e.g. use a dock or SATA to USB cable) and see if the MacBook boots correctly. You'll need to hold the alt key down when starting the MacBook to be able to select the external drive.
This part has the IR sensor but no indicator light or hard drive bracket attached. The indicator light and hard drive bracket can easily be swapped from an existing part.
Repair Stories
User avatar
Jeremy Adams's Story Photo #900128
My Problem
After replacing the DVD drive with a second HDD and the primary HDD with an SSD I thought I was all set for a better computing experience. Unfortunately, after only a couple of weeks the funky hard drive performance I was experiencing before I replaced the HDD with an SSD returned. At the time I tho . . .
User avatar
paula's Story Photo #511044
My Problem
When my Macbook hard drive failed and could not be repaired, my son the certified geek recommended an upgrade to a solid state drive to improve the performance. He predicted that "there might be a compatibility problem between the newer, faster drive and the original cable", but it "might" work, so . . .
User avatar
My Problem
My mac would get 1/2 way through the startup and crash out. Then start again only to crash out again. Disk utility said everything was a ok.
My Fix
Replaced the hd cable and everything worked great. Took the time to swap out the old 500gb hard drive for a new ssd. Now the computer works about twice as fast. . . .
User avatar
My Problem
They have a problem with all MBP mid 2009 about the EFI firmware and cable that can do highest speed at 1.5Ghz. So I ordered and change them myslef. Apple doesn't even responsible for this. This probably my last Apple computer, now I use PC and very happy.
My Fix
It's easy. I just watched youtube for that. . . .
User avatar
My Problem
No communication anymore between the HDD and the Main Board (CPU), while all OK with an external SDD on the external USB socket of the MacBook Pro.
My Fix
Direct & easy internal replacement.
A quarter of an hour operation.
My Advice
Took advantage of the repair to replace the 500GB HDD by a 1TB Samsung 840 EVO.
All we . . .
User avatar
My Problem
Hard Drive had stopped working and thought I had a virus on Mac...what? Nope, just a worn out Hard Drive cable like so many others
My Fix
The repair went smoothly and quickly thanks to a perfect product and excellent online directions at iFixit. I even added a 2nd Hard Drive while I was under the hood in . . .
User avatar
My Problem
I noticed there were read/write errors and the hard drive had all ready been replaced.
My Fix
The replacement SATA cable did the trick.
My Advice
Careful removing the original cable from the second bracket, it's not difficult to do, just be patient with it.
User avatar
My Problem
My computer will not boot; get question mark when the computer is started. I was sure my HD had died but before I ordered a new HD pulled it from he computer and found it worked fine when plugged in as an external drive. After a bit of reading heard that the HD cable can go bad.
My Fix
The repair was ext . . .
User avatar
My Problem
Macbook Pro starting to crash a few times when using, and reboot or startup encountered slow startup & slow progress bar. Performance was very slow when using... and noticed the laptop was extremely warm where the hard drive is located. Assume the hard drive was going bad...Took my mid-2009 Macbook . . .
User avatar
My Problem
My documents wouldn't save, apps wouldn't open, and I could only start my computer here and here. The hard drive is new so I decided to fix the cable since apple led me in that direction.
My Fix
The step by step guide was super easy. Well done iFixit!
My Advice
Follow the guide step by step and you won't have any issu . . .
Show more
