MacBook Pro 15" Unibody Late 2008 through Late 2011 LCD Panel
  • MacBook Pro 15" Unibody Late 2008 through Late 2011 LCD Panel
May have some minor scratches and/or dead pixels.
Condition: Used
$107.99
$107.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Replacement display panel for 15.4" Unibody displays. Compatible with all 15" Unibody MacBook Pros. 15.4” screen. 1440x900 or 1680x1050 resolution options. Glossy, anti-glare, and high-resolution options.
Disclaimer
This part does not include bezels, hinges, metal frame, cables, or iSight camera.
Compatibility
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
MacBook Pro 15" Unibody Early 2011
2 GHz
2.2 GHz
2.3 GHz
MacBook Pro 15" Unibody Late 2008 and Early 2009
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
2.93 GHz
MacBook Pro 15" Unibody Late 2011
2.2 GHz
2.4 GHz
2.5 GHz
MacBook Pro 15" Unibody Mid 2009
2.66 GHz
2.8 GHz
3.06 GHz
MacBook Pro 15" Unibody Mid 2010
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
Show 3 more devices
Repair Stories
User avatar
patrash's Story Photo #229687
patrash's Story Photo #229688
My Problem
LCD on MacBookPro was damaged and didn´t work properly
My Fix
Like a charm!
It was a bit hard no exactly know how much heating had to be done to ensure that display glam could be removed from adhesive edge around the display. I think I accidently heated it too much and a huall area of the glam became a bi . . .
User avatar
My Problem
My lcd was bad
My Fix
As many others have said, getting the glass off was real tough, I found that when I wasn't having success in one corner, I tried a lower corner and it worked much better. From there I just pried all the way around, making sure to heat a bit as I went.
My Advice
I bought my led from Ifixit and the . . .
User avatar
My Problem
I always try to fix things myself, and my wifes laptop screen was not going to be an exception.
My Fix
Easy! Simple! Step by step instructions that even a monkey can learn to follow. This was my first time ever working on electronics, so it was a bit intimidating at first, but very easy. The parts i ordered . . .
User avatar
My Problem
Back of aluminum had something fall on it and dented right into the lcd , and broke it.
My Fix
Very well , easy followed instructions did it in just under an hour for disassembling . Part arrived the next day put it in and reassembled in less time .
I had to drill out some stripped screws .. No big deal . . . .
User avatar
My Problem
Il mio schermo LCD é morto ,fuori garanzia ovviamente costo riparazione 600 euro e più. Dopo aver messo del disossidante per contatti sul connettore dello schermo ha ricominciato a funzionare , peccato che abbia rovinato lo schermo
My Fix
Riparazione avvenuta con successo, a parte gli insetti dentro lo sc . . .
User avatar
My Problem
Screen was smashed so I had to fix it
My Fix
This was not easy, but definitely worth the work. The instructions on this website are superb
My Advice
Make sure to keep track of which screws go where!
User avatar
My Problem
Lcd was broken, its cheaper do it by yourself
My Fix
LCD was replaced flawlessly... the front glass didnt had the same fate.
My Advice
remove the front glass is very tricky, better consider have a spare front glass handy
User avatar
My Problem
Broken LCD w/ verticle bands of solid white/black.
My Fix
Reasonably well. Used a hair dryer instead of a heat gun. Had a lot of trouble getting LVDS cable (also replaced) to stay in the lcd when putting everything back together.
My Advice
My LCD panel has about 50 stuck red pixels all in a clump in the lower left cor . . .
User avatar
My Problem
My mac took a bit of a tumble and the bottom quarter of the screen was distorted to just lines. Took it into to an Apple store to make sure it was the right problem and see if it would at least be around the same price as fixing it myself, but ~$500 was a little pricey for me.
My Fix
I only had two issues c . . .
User avatar
My Problem
The late-2008 Macbook Pro 15" - after a lightning discharged quite nearby the screen acquired a bad habit of turning white washed out. Could be a coincidence or just a factor promoting a defect.
The washout could be remedied by a little pinching of the screen - so it was just a matter of time the g . . .
Show more
