MacBook Pro 15" Unibody (Early 2011-Mid 2012) Upper Case
  • MacBook Pro 15" Unibody (Early 2011-Mid 2012) Upper Case
$299.99
$299.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Replace a broken or damaged upper case compatible with your Early 2011 to Mid 2012 15" MacBook Pro Unibody with this part. This assembly includes backlit keyboard and battery level indicator assembly.
Note
Please read option to see if trackpad is included; if not, trackpads are available separately: Trackpad compatible with MacBook Pro 15" Unibody (Mid 2009 to Mid 2012)
Compatibility
Repair Stories
kennyfoner's Story Photo #246171
My Problem
My Problem
The keyboard had keys that weren't working.
My Fix
Thanks to the repair guide, the repair went very smoothly.
My Advice
1. Print out the guide and number little plastic baggies with the step number screws and small parts.
2. The trackpad connect/disconnect seemed to be missing, look it up on YouTube.
3. Take you . . .
My Problem
Coffee everywhere.
My Fix
Flawless. Took about 1.5 hours. I had already had this thing apart a few times so I felt like an expert... probably would have taken longer otherwise.
My Advice
- An empty icecube tray with post-it notes is a great way to keep track of screws and small parts along the way.
- Photos are a goo . . .
My Problem
My son spilled a glass of water on my wife's 2011 early macbook pro. The keyboard and trackpad no longer behaved properly
My Fix
The repair took a long time. It was difficult. But in the end it was successful.
My Advice
Take your time. It is a good idea to have an egg carton or ice tray (or two) to keep screws sorted . . .
My Problem
A client called with an issue.. "I spilled a DR Pepper on my my Macbook Pro *last week* and the keyboard stopped working. I used it with an external but now I get nothing." So, it's iFixit to the rescue. I searched for a replacement but all the pieces separate were just outrageous, but iFixit had it . . .
My Problem
Well the wife forgot the Mac was nearby while watering a plant and that was all it took. She didn't turn it off and tried to shake the water out. I let it sit for a few day after getting the water out of it, but the keyboard was toast.
My Fix
All went pretty much according to the guide. The display cable wa . . .
My Problem
I spilled wine on my laptop keyboard. It worked fine initially, but by the next morning, keys would not function and it became impossible to use. Not wanting to buy a new machine or send off the computer to Apple for an expensive repair, I bought the parts and tools straight from iFixit. I found . . .
My Problem
My MacBook Pro's upper case didn't look to good, after it fell like 1 meter. The internal parts survived the drop without any damage - yay!
My Fix
Definitely not an easy repair. The repair took me more than an hour.
My Advice
You'll need a good brain or some sort of system to know, where which screw goes...
My Problem
I spilled coffee over keyboard. So the keyboard didn't work anymore.
My Fix
With the instruction on ifixit website, it was quite easy and nothing complicated. Just needed proper tools and took time for me. Because it was the first time that I repair my computer by myself.
My Advice
The most difficult part for me was t . . .
My Problem
I spilled a soda all over my laptop. After drying it out, the only problem was the keyboard no longer worked correctly. Very sticky keys.
My Fix
It was great. Followed the directions to a tee. Worked perfectly.
My Advice
GET THE TOOLS... Tried to take apart some of this with my own tools and stripped two screws.. . . .
Show more
