MacBook Pro 15" Unibody (2.53 GHz Mid 2009) or 17" Unibody (Early/Mid 2009) Right Fan
  • MacBook Pro 15" Unibody (2.53 GHz Mid 2009) or 17" Unibody (Early/Mid 2009) Right Fan
$44.99
$44.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Make sure you have identified your MacBook Pro correctly. You can use our Identify Your Mac.
2.53 GHz Unibody 15" Macbook Pros have only one fan. For Unibody 17" MacBook Pros, if your screen is facing you, this is the fan on the right side of the machine.
Includes fan and surrounding metal bracket.
Compatibility
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
MacBook Pro 17" Unibody
2.66 GHz (Early 2009)
2.8 GHz (Mid 2009)
2.93 GHz (Early 2009)
3.06 GHz (Mid 2009)
Repair Stories
User avatar
jaytee0806's Story Photo #199805
jaytee0806's Story Photo #199807
jaytee0806's Story Photo #199809
My Problem
The left fan was making a very loud noise. Like the one you hear when you stick a baseball card in a bikes' spoke. But just to be safe I replaced the right fan too even though it wasn't giving me any problems.
My Fix
The repair was very easy. I removed the screws holding the bottom cover then the three scre . . .
User avatar
My Problem
Fan was overheating after 6/7 years of use, needed to replace and clean it out.
My Fix
Horribly. Broke off the connector being too rough with it. With my DIY attitude I bought a soldering iron and tried to solder it back on, instead I just fried my motherboard. Now I have to buy a whole new laptop.
My Advice
Listen t . . .
User avatar
My Problem
I noticed a while back that when watching a movie or using my MacBook for an extended period of time the fan on the left side would begin to get very loud and the left half of my MacBook would get very hot. I downloaded an app called "iStat" which monitors CPU usage, internal temps, fan speeds, etc . . .
User avatar
My Problem
My MacBook Pro had begun making an intermittent screeching noise after I accidentally dropped it. It only fell about a foot and a half but it was enough to damage something. The noise sounded like the tone of an an old fax machine, almost like the hard drive was girding away at a high pitch. The com . . .
User avatar
My Problem
At least one of the fans in my unibody MacBook Pro 17 was making pretty horrific noises. I've had this happen before in MacBook Pro systems. The poor little fans give their all and then die.
My Fix
I replaced both fans just to be sure, it took about 2 minutes to get the case open, and about 2 minutes each . . .
Show more
