MacBook Pro 15" Retina (Late 2013/Mid 2014) Display Assembly
  • MacBook Pro 15" Retina (Late 2013/Mid 2014) Display Assembly
Our used options may have as many as three (3) dead pixels, per industry standard and may have cosmetic blemishes to varying degrees. Also, some parts' outer housings may have been refurbished to remove dents and/or scratches. These refurbished parts may have a slightly different finish than an original part. The parts are fully functional.
$498.99
$498.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
See all those swell pixels again!
This assembly includes the Retina LCD screen, display cover, bezel, FaceTime HD Camera, clutch hinges, Wi-Fi antenna, camera, and display data cables.
Compatibility
MacBook Pro 15" Retina Display Late 2013
2.0 GHz (Integrated Graphics)
2.3 GHz (Dual Graphics)
2.3 GHz (Integrated Graphics)
2.6 GHz (Dual Graphics)
2.6 GHz (Integrated Graphics)
MacBook Pro 15" Retina Display Mid 2014
2.2 GHz (Integrated Graphics)
2.5 GHz (Dual Graphics)
2.5 GHz (Integrated Graphics)
2.8 GHz (Dual Graphics)
2.8 GHz (Integrated Graphics)
Repair Stories
User avatar
Daniel Bittencourt's Story Photo #1307799
Daniel Bittencourt's Story Photo #1307798
Daniel Bittencourt's Story Photo #1307800
My Problem
I was using the notebook in the sofa and left it on the sofa arm. When I threw myself in the sofa while seating, the notebook jumped and hit the floor while the screen was open, creating a strip of dead pixels of 5 centimeters on the left side.
Took to repair it, but as my computer had just came out . . .
User avatar
Joshua Espinosa-Pimentel's Story Photo #1207671
Joshua Espinosa-Pimentel's Story Photo #1207673
My Problem
The reason I needed to fix my MacBook Pro is because my children thought it was a device like their iPads and while I was away in the restroom They were pressing on my Mac Screen and when I came back it was cracked straight down the middle no screen breakage but only gave me limited visibility of my . . .
User avatar
Jon Lucenius's Story Photo #1397665
My Problem
LCD screen broke after a fall
My Fix
Repair went very well. Each step was clearly explained. No issues encountered with the repair.
My Advice
Afterwards the backlit keyboard did not work. I rebooted and held down CMD-OPT-P-R to reset the parameter RAM. The backlit keyboard worked fine after that quick fix.
User avatar
My Problem
LCD screen was distorted. Could only see half of screen
My Fix
Repair was simple and easy.
My Advice
Purchased tools from Amazon.
User avatar
My Problem
My dog knocked my laptop off the couch -- the LCD was clearly damaged (vertical and horizontal lines of solid-colored pixels, giant black spot on the right quarter of the screen), but the glass wasn't broken. The picture on my external monitor was fine when I plugged it in, so I was pretty sure it w . . .
User avatar
My Problem
The screen was broken from a drop onto the floor.
My Fix
Repair went fine. Previous experience with iphone repair helped.
My Advice
Remember to blow out some dust from the inside of the laptop as well while you're in there.
User avatar
My Problem
I have concrete floors, and the laptop had a bad experience meeting them once.
My Fix
Couldn't have gone smoother. I've worked on many Apple products over the years, various iPhones, and laptops but I was still slightly intimidated. The instructions are excellent, as always, and the repair job was actually . . .
User avatar
My Problem
My LCD was broken.
My Fix
It went well and I didn't have any issues. I took some extra time to make everything slowly and don't try to rush it if you do it for the first time.
My Advice
Reading all the comments below each step was very helpful as I found similar questions as other users had.
User avatar
My Problem
The MBP got dropped and landed on a corner of the top cover, resulting in a visible bend and a scrambled screen.
My Fix
The instructions were great. I worked through them slowly and meticulously, taking probably closer to 1.5 hours all up. I also took the opportunity to blow out all the accumulated dust a . . .
User avatar
My Problem
Screen cracked by closing lid on charge cord and cat stepped on it.
My Fix
My daughter wanted to do her own repair and I helped a little. The Airport card cables gave us a little trouble, but using a magnifying glass helped see that the connectors needed to be perfectly aligned to ensure fit. Bending the . . .
Show more
