MacBook Pro 15" Retina (Late 2013-Mid 2014) Battery
  • MacBook Pro 15" Retina (Late 2013-Mid 2014) Battery / New / Fix Kit
  • MacBook Pro 15" Retina (Late 2013-Mid 2014) Battery / New / Part Only
  • 360°
360
New battery guaranteed at capacity greater than 8020 mAh.
$89.99
$89.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
This replacement battery is what you need to get your MacBook Pro 15" Retina (Late 2013/Mid 2014) back in action! These batteries are adhered to the upper case of the computer so removing them isn't as straightforward as we'd like it to be. Be sure you have all the right tools—and follow our repair guide when making the repair.
Part Assembly Includes
  • MacBook Pro 15" Retina (Late 2013/Mid 2014) Battery
  • Installation adhesive
Kit Contents
Kit Contents
Note
Lithium ion battery shipping regulations limit the shipping methods for orders containing batteries. Domestic orders may only be shipped via Standard shipping. iFixit is not able to ship batteries internationally or outside the contiguous US at this time. iFixit Customer Support will contact you if your order needs to be modified after it is placed.'
Disclaimer
MacBook Pro Retina batteries are originally adhered to the upper case assembly as a single part from Apple. The parts we sell may have been separated from this assembly. Consequently, the battery adhesive may have some cosmetic flaws.
Warning
Lithium-ion batteries pose a fire hazard if they begin to swell due to age or defect. Learn more about how to safely handle a battery that may be swollen.
Compatibility
MacBook Pro 15" Retina Display Late 2013
2.0 GHz (Integrated Graphics)
2.3 GHz (Dual Graphics)
2.3 GHz (Integrated Graphics)
2.6 GHz (Dual Graphics)
2.6 GHz (Integrated Graphics)
MacBook Pro 15" Retina Display Mid 2014
2.2 GHz (Integrated Graphics)
2.5 GHz (Dual Graphics)
2.5 GHz (Integrated Graphics)
2.8 GHz (Dual Graphics)
2.8 GHz (Integrated Graphics)
Repair Stories
Christopher Little's Story Photo #1394565
My Problem
A customer complained that his battery was no longer charging or supplying battery power. Once I was able to get his laptop, I did a quick check on the battery (Control-Click the battery icon) and determined that the system was advising for an immediate replacement. That's when I thought of iFixit . . .
My Problem
Battery was completely drained and would not hold a charge after sitting for a few years.
My Fix
The repair wasn't too bad once I had the right tools (I thought I had a set of pentalobes but ended up having to borrow them). It took a bit more than an hour, but I think I could do it in 45 minutes or so if I . . .
My Problem
The battery had swollen so much, the clamshell would not close. When opening the Mac, the casing just popped off because the metal was so stressed.
My Fix
The repair went as exactly described by ifixit. Even though you’re dealing with delicate micro electronics, when I put everything back together and p . . .
My Problem
750 cycles on battery.
My Fix
Skipped the disassembly. Went for dental floss under the battery.
My Advice
I kept shredding or breaking the floss trying to keep it low. Then I switched to sawing motion that went straight up from the plane of the laptop. Worked great, cut right through it.
My Problem
The trackpad on the Macbook stopped responding due to the batteries swelling underneath.
My Fix
The repair went smoothly except for the removal of the batteries themselves. The glue was extra strong and required +30 minutes to saw them out with a combination of the iFixit solution and the use of string as a . . .
My Problem
Old Battery with no life
My Fix
Took about 1.5 hours. About an hour to disassemble and 30mins to reassemble. I went slow and kept all of the screws organized - I could probably repeat in half the time. I used the occasion to clean out some dust and dirt. Certainly easier then replacing most phone screens a . . .
My Problem
1700 cycles on my original battery.
My Fix
A+
My Advice
I did not take my logic board or any other components out. I feel that as long as you are careful, this is a perfectly fine approach.
I followed this video more or less: https://www.youtube.com/watch?v=rfHHIERH...
Like the video, I used some thread to get each . . .
My Problem
My daughters Mac Book Pro had stopped charging. Because of the gradual way it had failed I was thinking it might be the battery so I located and order the appropriate kit. It arrived within days and contained everything needed to make the battery change.
My Fix
The instructions and pictures were clear and c . . .
My Problem
The original batteries in the late 2013 MBP was bulging. It was their time to retire. :(
My Fix
The repair went smoothly without any snags... but only with the help of an external source. Methods described on the iFixIt tutorial was simply way too complicated and would actually introduce more complications . . .
My Problem
My battery was swelling to double it's original size
My Fix
It went well. The only issue I had was that I broke the plastic around one of the speaker wires. It still connected properly and works, so not too bad of a thing.
My Advice
Be careful when disconnecting cables. Also, make a note of the cables you disconnected . . .
Show more
