MacBook Pro 15" (Model A1211, A1226, and A1260) Right Fan
  • MacBook Pro 15" (Model A1211, A1226, and A1260) Right Fan
$49.99
$49.99
We'll send a message when the product is back in stock.
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Product Details
Description
Description
Make sure you have identified your MacBook Pro correctly. You can use our Identify Your Mac.
If your screen is facing you, this is the fan on the right side of the machine. Includes fan and surrounding metal bracket.
Wind currents are prized for their mysterious ability to generate energy in windmills, send ships across vast oceans, and affordably distribute vagrant-authored novellas . Blast mediocre literature into your Pro today with our MacBook Pro 15" right fan.
Compatibility
MacBook Pro 15" Core 2 Duo Model A1211
2.16 GHz
2.33 GHz
MacBook Pro 15" Core 2 Duo Models A1226 and A1260
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
2.4 GHz (Santa Rosa)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.6 GHz (Santa Rosa)
Repair Stories
My Problem
The fan was noisy for a long time, though I haven't been using this old computer 15" Macbook Pro 2008.. Now I needed it as an Arduino development station.
My Fix
trivial, no surprises. Now It runs Linux (Fedora 27), the Fedora system management tools are fully compatible, I can see the power data and the . . .
My Problem
Fan noise was annoying and increasing in volume
My Fix
Using the repair guide everything went smoothly. The mac is as quiet as a mouse.
My Advice
Be sure to keep track of the screws both the number and their original location.
My Problem
The original fan was, how should I say it...sounding like a freight train derailing in a crowded intersection.
My Fix
The repair went without any issues. Once I installed the fan, laptop is back to its whispery quiet old self.
My Advice
Use iFixit. The warranty is a stress reliever, and they provide detailed instruc . . .
My Problem
R/h fan failure
My Fix
Replaced fan with iFixit part and guide and it works great!
My Advice
Trust iFixit!
My Problem
After, um, 10 years! the right side fan on my 2006 vintage MBP gave up the bearings and was pretty noisy. Time to replace it.
My Fix
Repair went w/o a hitch. This is the 3rd time I've opened the machine (SSD, new keyboard) so I knew what to expect. Had the tools including the spudger from earlier forays. . . .
My Problem
noisy fans and not yet working cd rom
My Fix
all good
My Advice
no
My Problem
The fan started to be noisy and quite annoying.
Hoping noisy sound would just go away bit did not, LOL.
My Fix
The process went well except for one nasty screw that won't unscrew easily.
And by the way, the Phillips #00 screwdriver you sent didn't work well and did not fit the screws... So I had to get a . . .
My Problem
Aucun problème. C'est un achat de précaution. J'ai déjà changé le ventilateur gauche récemment. Le droit peut lâché prochainement...
My Fix
La réparation se passera plus tard, probablement bien, avec votre aide.
My Advice
Aucun conseil. Continuez comme ça.
My Problem
The right fan was making a horrible noise. It started out sounding like a purring kitten, and turned in a snoring fat tiger. It was unbearable to work on.
My Fix
I followed the iFixit Guide and had no problems. Step by step got me in and replaced the fan. I looked around and the best deal I found was throug . . .
My Problem
right fan on MacBookPro went crazy. Unbearable noise.
My Fix
I followed iFixit step-by-step, got the fan out, cleaned & added a drop of WD-40. Was OK for a day, but then noisy again. Ordered replacement - used - from iFixit. Opened MBP up again, swapped the fan - now running again super quiet. Very sati . . .
Show more
