MacBook Pro 15" Late 2008 through Mid 2012 (excluding Mid 2009 2.53 GHz) Left Fan
$59.99
$59.99
We'll send a message when the product is back in stock.
New Battery = Faster iPhone
Fix Kits starting at $16.99
Product Details
Features
Features
Make sure you have identified your MacBook Pro correctly. You can use our Identify Your Mac.
If your screen is facing you, this is the fan on the left side of the machine. Includes fan and surrounding metal bracket.
Compatibility
MacBook Pro 15" Unibody Early 2011
2 GHz
2.2 GHz
2.3 GHz
MacBook Pro 15" Unibody Late 2008 and Early 2009
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
2.93 GHz
MacBook Pro 15" Unibody Late 2011
2.2 GHz
2.4 GHz
2.5 GHz
MacBook Pro 15" Unibody Mid 2009
2.66 GHz
2.8 GHz
3.06 GHz
MacBook Pro 15" Unibody Mid 2010
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
MacBook Pro 15" Unibody Mid 2012
2.3 GHz
2.6 GHz
2.7 GHz
Show 3 more devices
Repair Stories
User avatar
My Problem
The left fan was making noise.
My Fix
Repair went smooth, easy to remove and install the new fan.
My Advice
Be careful, screws are really small, pay attention to what length screw goes in each location.
User avatar
My Problem
Fan was making horrible noise at times.
My Fix
Repair was really simple. Basically remove the bottom plate to get inside the computer then removed 3 screws holding the fan in place. Used a plastic pry tool to gently disconnect the fan from connector and put the new one in, in a flash.
My Advice
Just make sure you hav . . .
User avatar
My Problem
Left fan on a MacBook Pro - was very noisy
My Fix
Perfect /easy - iFixit instructions were fantastic.
My Advice
Check the iFixit list before you just click on the tools they recommend - they should also recommend an anti-static wrist loop. Also use an egg box or daily/weekly pill dispenser to keep all the little scre . . .
User avatar
My Problem
Left fan runs / stops randomly, and makes big noise!
My Fix
Easy to replace within 10 min.
My Advice
To browse infixit instruction before fixing it. It is hopeful!
User avatar
My Problem
Had to change the battery in my 5 year old MacBook Pro 15"
My Fix
The service and delivery speed was top notch!
Installed the new battery I got from Ifixit.
What bothers me is that the new battery is not as good as I expected.
It drains fairly quickly, almost the same speed as the old one.
The situation i . . .
User avatar
My Problem
The fans on my MacbookPro had been running constantly due to some software that seemed to need 1 CPU to run constantly to check web pages. After finally figuring out which software to trash and reducing use of the fan, the wear and tear of this bad software took its toll and eventually the fans sta . . .
User avatar
My Problem
My brother's Macbook Pro was making some interesting sounds on top of overheating. We did some research and came across ifixit.com how-to articles. From there, I ordered the fans (used), and the problem was fixed!
My Fix
Removing and replacing the right and left fans (Macbook Pro 15 mid-2009 2.8 GHz model) . . .
User avatar
My Problem
fans started making grinding noise so had to replace
My Fix
No problems. Easy and didn't take long
My Advice
Make sure to clean out the intake grills before you switch up your fans, and it's probably a good idea to start cleaning out that dust every 6 months or so
User avatar
My Problem
Mis ventiladores hacían muchísimo ruido, ni se iba con lubricante especial para ventiladores.
My Fix
Ventiladores como nuevo. Silencio absoluto. Paquete bien protegido. Atención, servicio y rapidez de entrega inmejorable.
Valoración 12 sobre 10.
My Advice
Lamento que en su página en Europa, no tengan existencias, . . .
User avatar
My Problem
leftFAN noises and damaged
rightFAN was ok but i want to change it
My Fix
All perfect, except for the rightFAN. I can't unscrew the old one, the screw is locked!
My Advice
nn
Show more
