Parts Mac MacBook Pro 15" (Non-Unibody) SSD Enclosures
Store
Don't know your model? ID Your Mac
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
$7.99
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade bundle.
From $89.99
Silicone 2.5" Hard Drive Enclosure with USB 2.0 Cable
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part.
$9.99
Universal Drive Adapter
Turn your current hard drive into an external drive with this part.
$24.99
500 GB 5400 RPM 2.5" Hard Drive / Toshiba
Replacement or upgrade hard drive compatible with all MacBooks, MacBook Pros, Intel Mac minis, and Sony PS3 and PS3 Slim game consoles. SATA interface for Intel Macs / 2....
$54.99
MacBook Pro 15" Replacement Battery
Replace a dead or damaged battery in your MacBook Pro 15" with this part. This part is compatible with all 15" MacBook Pros (excluding Unibody).
$59.99
G4/MagSafe AC Adapter End
Replace a broken or damaged two-pronged tip of your square G4 or MagSafe adapter with this part.
$7.99
1 TB 5400 RPM 2.5" Hard Drive / Toshiba
Replace or upgrade the hard drive in your compatible MacBook, MacBook Pro, Intel Mac mini, and Sony PS3/PS3 Slim/PS4 game consoles.
$74.99
PC2-5300 1 GB RAM Chip
RAM Upgrade / 1 GB / PC2-5300 / Low Profile / 200 pin, 667 MHz
$8.99
Showing products 1 - 10 of 122
Device Info
The MacBook Pro 15" replaced the Aluminum 15" and features Intel support and an integrated iSight camera.
All MacBook Pro 15" Non-Unibody models use PC2-5300 RAM. Two RAM slots means an easy memory upgrade! If storage is an issue, any 9.5mm SATA hard drive will expand your boundaries.
Heat has always been an issue for MacBook Pros. It's possible that a bad thermal sensor or fan will prevent the machine from booting.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Non-Unibody repair guides for step-by-step instructions on how to make the fix.
