MacBook Pro 15" (Non-Unibody) Logic Boards
Grab a toolkit for your MacBook Pro 15" (Non-Unibody) model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Choose your model of MacBook Pro 15" (Non-Unibody):
Parts that work with MacBook Pro 15" (Non-Unibody):
MacBook Pro 15" (Model A1150) 2.16 GHz Logic Board
Replace a 2.16 GHz logic board (motherboard) compatible with the model A1150 MacBook Pro 15" laptop. Included Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 400, USB ...
MacBook Pro 15" (Model A1150) 2 GHz Logic Board
Replace a 2 GHz logic board (motherboard) compatible with the MacBook Pro 15" Model A1150 laptop. Included Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 400, USB 2.0...
MacBook Pro 15" (Model A1150) 1.83 GHz Logic Board
Replace a 2 GHz logic board (motherboard) compatible with the Model A1150 MacBook Pro 15" laptop. Included Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 400, USB 2.0...
MacBook Pro 15" (Model A1211) 2.16 GHz Logic Board
Replace a 2.16 GHz Core 2 Duo logic board (motherboard) compatible with the model A1211 MacBook Pro 15" laptop. Included Ports: DVI Video Out, 1000BaseT Ethernet, Firewir...
MacBook Pro 15" (Model A1211) 2.33 GHz Logic Board
Replace a 2.33 GHz Core 2 Duo logic board (motherboard) compatible with the model A1211 MacBook Pro 15" laptop. Included Ports: DVI Video Out, 1000BaseT Ethernet, Firewir...
MacBook Pro 15" (Model A1226) 2.2 GHz Logic Board
Replace a 2.2 GHz Core 2 Duo logic board (motherboard) compatible with the model A1226 MacBook Pro 15" laptop. Included Ports: DVI Video Out, 1000BaseT Ethernet, Firewire...
MacBook Pro 15" (Model A1226) 2.4 GHz Logic Board
Replace a 2.4 GHz logic board (motherboard) compatible with the Model A1226 MacBook Pro 15" laptop. Fix processing issues like unexpected shutdowns, reboots, or water dam...
MacBook Pro 15" (Model A1260) 2.4 GHz Logic Board
Replace a 2.4 GHz Core 2 Duo Penryn logic board (motherboard) compatible with the model A1260 MacBook Pro 15" laptop. Included Ports: DVI Video Out, 1000BaseT Ethernet, F...
MacBook Pro 15" (Model A1260) 2.5 GHz Logic Board
Replace a 2.5 GHz Core 2 Duo Penryn logic board (motherboard) compatible with the model A1260 MacBook Pro 15" laptop. Included Ports: DVI Video Out, 1000BaseT Ethernet, F...
MacBook Pro 15" (Model A1226) 2.6 GHz Logic Board
Replace a 2.6 GHz Core 2 Duo Santa Rosa logic board (motherboard) compatible with the model A1226 MacBook Pro 15" laptop. Included Ports: DVI Video Out, 1000BaseT Etherne...
Device Info
The MacBook Pro 15" replaced the Aluminum 15" and features Intel support and an integrated iSight camera.
All MacBook Pro 15" Non-Unibody models use PC2-5300 RAM. Two RAM slots means an easy memory upgrade! If storage is an issue, any 9.5mm SATA hard drive will expand your boundaries.
Heat has always been an issue for MacBook Pros. It's possible that a bad thermal sensor or fan will prevent the machine from booting.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Non-Unibody repair guides for step-by-step instructions on how to make the fix.
