MacBook Pro 15" Unibody Logic Boards
Grab a toolkit for your MacBook Pro 15" Unibody model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Choose your model of MacBook Pro 15" Unibody:
Parts that work with MacBook Pro 15" Unibody:
MacBook Pro 15" Unibody (Mid 2012) 2.3 GHz Logic Board
Replace a 2.3 GHz Core i7 logic board (motherboard) compatible with the Mid 2012 MacBook Pro 15" Unibody laptop. Included Ports: Thunderbolt (Mini DisplayPort), 1000BaseT...
MacBook Pro 15" Unibody (Late 2008-Early 2009) 2.4 GHz Logic Board
Replace a 2.4 GHz logic board (motherboard) compatible with the Late 2008 to Early 2009 MacBook Pro 15" Unibody laptop. Fix processing issues like unexpected shutdowns, r...
MacBook Pro 15" Unibody (Mid 2009) 2.66 GHz Logic Board
Replace a 2.66 GHz logic board (motherboard) compatible with the Mid 2009 MacBook Pro 15" Unibody laptop. Includes attached heat sink and thermal paste. Fix processing is...
MacBook Pro 15" Unibody (Mid 2009) 2.8 GHz Logic Board
Replace a 2.8 GHz logic board (motherboard) compatible with the Mid 2009 MacBook Pro 15" Unibody laptop (excluding the 2.53 GHz model). Included Ports: Mini DisplayPort, ...
MacBook Pro 15" Unibody (Mid 2009) 3.06 GHz Logic Board
Replace a 3.06 GHz logic board (motherboard) compatible with the Mid 2009 MacBook Pro 15" Unibody laptop. Included Ports: Mini DisplayPort, 1000BaseT Ethernet, Firewire ...
MacBook Pro 15" Unibody (Mid 2009) 2.53 GHz Logic Board
Replace a 2.53 GHz logic board (motherboard) compatible with the Mid 2009 MacBook Pro 15" Unibody laptop. Included Ports: FireWire 800, Mini DisplayPort, 1000BaseT Ethern...
MacBook Pro 15" Unibody (Mid 2010) 2.4 GHz Logic Board
Replace a 2.4 GHz logic board (motherboard) compatible with the Mid 2010 MacBook Pro 15" Unibody laptop. Fix processing issues like unexpected shutdowns, reboots, or wate...
MacBook Pro 15" Unibody (Mid 2010) 2.53 GHz Logic Board
Replace a 2.53 GHz logic board (motherboard) compatible with the Mid 2010 MacBook Pro 15" Unibody laptop. Fix processing issues like unexpected shutdowns, reboots, or wat...
MacBook Pro 15" Unibody (Mid 2010) 2.66 GHz Logic Board
Replace a 2.66 GHz logic board (motherboard) compatible with the Mid 2010 MacBook Pro 15" Unibody laptop. Fix processing issues like unexpected shutdowns, reboots, or wat...
MacBook Pro 15" Unibody (Early 2011) 2.0 GHz Logic Board
Replace a 2.0 GHz Core i7 logic board (motherboard) compatible with the Early 2011 MacBook Pro 15" Unibody laptop. Included Ports: Thunderbolt (Mini DisplayPort), 1000Bas...
Device Info
In October of 2008 Apple released the MacBook Pro 15" Unibody with an aluminum case drilled from a single aluminum brick. With the exception of the 2.53 GHz Mid 2009 model, all 15" Unibody models feature 2 graphics cards, one for power saving casual use and one for graphics-intensive processing.
The most common repairs with the MacBook Pro 15" Unibody models are replacing a dead battery, upgrading the hard drive, or upgrading the RAM. Choose a model for more specific information.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Unibody MacBook Pro 15" Unibody Repair for step-by-step instructions on how to make the fix.
