MacBook Pro 15" Unibody Mid 2010 Case Components
Grab a toolkit for your MacBook Pro 15" Unibody Mid 2010 model and bring your laptop back to life!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Parts that work with MacBook Pro 15" Unibody Mid 2010:
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Trackpad
Replace a trackpad compatible with the Mid 2009 to Mid 2012 model A1286 MacBook Pro 15 inch Unibody laptop. Part #922-9035, 922-9306, 922-9749.
MacBook Pro 15" Unibody (Mid 2010-Mid 2012) Lower Case
Replace a broken or damaged lower case for your Mid 2010 to Mid 2012 MacBook Pro 15" Unibody with this part. This part includes 4 rubber feet.
MacBook Pro 15" Unibody (Mid 2010) Upper Case
Replace an upper case, backlit keyboard, and battery level indicator compatible with the Mid 2010 model A1286 MacBook Pro 15 inch Unibody laptop. Part #661-5481.
MacBook Pro Unibody (Mid 2009-Mid 2012) Trackpad Mounting Screws
Replacement screws and springs for mounting the trackpad in the upper case assembly of your mid 2009 to mid 2012 13" and 15" MacBook Pro Unibody laptop.
Device Info
The Mid 2010 version of MacBook Pro 15" Unibody features an upgraded graphics chip, new Core i5 or Core i7 processors, and a hefty internal battery that boasts up to 9 hours of life between charges.
The most common repairs with Mid 2010 model MacBook Pro 15" Unibody laptops are replacing a dead battery, replacing a malfunctioning left or right fan, and upgrading the hard drive or RAM. The MacBook Pro 15" Unibody (Mid 2010) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 8 GB of RAM.
The Mid 2010 model MacBook Pro 15" Unibody requires a Tri-point Y0 Screwdriver to remove the battery. Our battery repair kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Unibody Mid 2010 repair guides for step-by-step instructions on how to make the fix.
