MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Optical Drives
Grab a toolkit for your MacBook Pro 15" Unibody 2.53 GHz Mid 2009 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Parts that work with MacBook Pro 15" Unibody 2.53 GHz Mid 2009:
Unibody Laptop Dual Drive
Increase the storage space in your laptop by replacing the optical drive with a second hard drive or SSD.
SATA Optical Drive USB Cable
Connect an optical drive to your computer via USB with this part.
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) 8x SATA SuperDrive (Used)
Replace a broken or damaged SuperDrive for your Mid 2009 to Mid 2012 MacBook Pro 15" Unibody with this part. This part includes the metal mounting bracket but does not in...
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) SATA SuperDrive Cable
Replace a damaged or missing cable connecting the SuperDrive to the logic board.
Unibody (Post-Early 2009) 8x SATA SuperDrive
Replace a broken or damaged SuperDrive for your Post-Early 2009 MacBook Unibody with this part. This part does not include the metal mounting bracket and orange ribbon ca...
Device Info
The 2.53 GHz Mid 2009 version of the MacBook Pro 15" Unibody shares more in common with the MBP 13" Unibody than other MBP 15" Unibody models. The 2.53 GHz machine features a single fan and graphics chip with shared memory.
The most common repairs with 2.53 GHz Mid 2009 model MacBook Pro 15" Unibody laptops are replacing a dead battery, replacing a malfunctioning fan, and upgrading the hard drive or RAM. The MacBook Pro 15" Unibody (2.53 GHz Mid 2009) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 8 GB of RAM.
The 2.53 GHz Mid 2009 model MacBook Pro 15" Unibody requires a P6 Pentalobe screwdriver to remove the battery. Our battery repair kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Unibody 2.53 GHz Mid 2009 repair guides for step-by-step instructions on how to make the fix.
