Parts Mac MacBook Pro 15" Touch Bar Mid 2018 Hard Drive Enclosures
Store
Grab a toolkit for your MacBook Pro 15" Touch Bar Mid 2018 model and fix a broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Don't know your model? ID Your Mac
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
$7.99
MacBook Pro 15" Retina (Late 2016-2019) Right Speaker / New
Replace a damaged or malfunctioning speaker compatible with a Late 2016 to 2019 model MacBook Pro 15" with Touch Bar.
From $14.99
MacBook Pro 15" Retina (Late 2016-2019) Left Speaker
From $14.99
MacBook Pro 15" Retina (Late 2016-2019) Left Fan
Replace a defective or noisy fan compatible with a 2016 to 2019 model 15" MacBook Pro with Retina Display.
From $49.99
MacBook Pro 15" Retina (Late 2016-2019) Display Cable
Replace the short flex cable that connects the display daughter board to the logic board.
From $19.99
MacBook Pro Retina (A1989 & A1990 Mid 2018-2019) USB-C Board
Replace one of the thunderbolt connector boards from the left or right side of your laptop.
$34.99
MacBook Pro 15" Retina (Late 2016-2019) Heat Sink / Used
Replace a damaged heat sink compatible with a 2016 to 2019 model 15" MacBook Pro with Retina Display.
From $39.99
MacBook Pro 15" Retina (Late 2016-2019) Lower Case / New / Dark Gray
Replace a scratched or dented lower case compatible with a 2016 to 2019 model 15" MacBook Pro with Retina Display.
From $49.99
MacBook Pro 15" Retina (Late 2016-2019) Trackpad / New / Dark Gray
Replace a damaged or malfunctioning trackpad compatible with a Late 2016 to 2019 model MacBook Pro 15" with Retina Display and Touch Bar.
From $79.99
Showing products 1 - 10 of 36
Device Info
Released in July 2018 as model A1989, this MacBook Pro features Coffee Lake processors up to the 2.9GHz Intel Core i9 processor with Turbo Boost up to 4.8 GHz.
The most common repairs with the 15" MacBook Pro Retina Mid 2018 laptops are replacing a dead battery, replacing a malfunctioning left or right fan, or a damaged display assembly.
The battery in a MacBook Pro 15" Retina Mid 2018 is adhered to the inside of the upper case. Our replacement batteries include the needed adhesive.
The MacBook Pro 15" Mid 2018 models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Retina Display Mid 2018 repair guides for step-by-step instructions on how to make the fix.
