Parts Mac MacBook Pro 15" Retina iFixit Exclusives
Store
Don't know your model? ID Your Mac
MacBook Pro Retina (A1425, A1502, and A1398) Plastic Feet / Part Only
Replace missing or damaged black plastic feet on your laptop's lower case.
From $4.99
MacBook Pro 15" Retina (Late 2013-Mid 2014) Battery / New / Fix Kit
Replacement 8440 mAh battery compatible with a MacBook Pro 15" Retina (Late 2013/Mid 2014) laptop.
From $89.99
MacBook Pro 15" Retina (Mid 2015) Battery / New / Fix Kit
Replacement 8760 mAh battery compatible with a MacBook Pro 15" Retina (Mid 2015)
From $99.99
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
$8.99
MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery / New / Fix Kit
This replacement 8680 mAh battery is compatible with a MacBook Pro 15" Retina (Mid 2012/Early 2013).
From $89.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
$7.99
OWC Aura Pro X2 SSD
OWC Aura Pro X2 SSD
Replace or upgrade the PCIe solid-state drive in a variety of Macs.
From $149.99
MacBook Pro Retina (2012-2015) Lower Case Screw Set / Part Only
Replace a stripped or missing screw securing the lower case.
From $19.99
MacBook Pro 15" Retina (Mid 2012-Mid 2014) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard compatible with a model A1398 15" MacBook Pro with Retina display from Mid 2012 to mid 2014.
$19.99
MacBook Pro 15" Retina (Mid 2012-Mid 2015) Right Speaker
Replace a broken or damaged right speaker for your Mid 2012 to Mid 2015 MacBook Pro 15" Retina laptop with this part and fix sound issues.
$29.99
Showing products 1 - 10 of 134
Device Info
In June 2012 Apple released the MacBook Pro 15" with a new Retina display with a 2880-by-1800 resolution. The Retina display models that followed the 2012 model vary by specifications and features.
The most common repairs with the 15" MacBook Pro with Retina Display laptops are replacing a dead battery or a damaged display assembly. Choose a model for more specific information.
The MacBook Pro 15" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Retina Display repair guides for step-by-step instructions on how to make the fix.
