MacBook Pro 15" Retina Case Components
Grab a toolkit for your MacBook Pro 15" Retina model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Choose your model of MacBook Pro 15" Retina:
Parts that work with MacBook Pro 15" Retina:
MacBook Pro 15" Retina (Late 2013-Mid 2014) Upper Case Assembly
Replace an upper case assembly compatible with the MacBook Pro 15 inch Retina Late 2013 to Mid 2014 model A1398. Part #661-8311.
MacBook Pro 15" Retina (Late 2013-Mid 2015) Lower Case
Replace a scratched or dented lower case compatible with a Late 2013 to Mid 2015 MacBook Pro 15" Retina laptop.
MacBook Pro 15" Retina (Mid 2012-Early 2013) Trackpad
Replace a trackpad compatible with the mid 2012 or early 2013 model A1398 MacBook Pro 15 inch Retina laptop. Part #661-8311, 661-6532.
MacBook Pro 15" Retina (Late 2016-2017) Upper Case
Replace a scratched or dented upper case or malfunctioning keyboard compatible with a 2016 or 2017 model 15" MacBook Pro with Retina Display.
MacBook Pro 15" Retina (Mid 2018-2019) Upper Case Assembly
Replace an upper case, keyboard, and battery compatible with the 2018 and 2019 model A1990 MacBook Pro 15 inch Retina laptop.
MacBook Pro 15" Retina (Late 2016-2019) Lower Case
Replace a scratched or dented lower case compatible with a 2016 to 2019 model 15" MacBook Pro with Retina Display.
MacBook Pro 15" Retina (Mid 2012-Early 2013) Upper Case Assembly
Replace an upper case and keyboard compatible with the Mid 2012 to Early 2013 Retina 14" MacBook Pro laptop.
MacBook Pro 15" Retina (Late 2016-2019) Trackpad
Replace a damaged or malfunctioning trackpad compatible with a Late 2016 to 2019 model MacBook Pro 15" with Retina Display and Touch Bar.
MacBook Pro 15" Retina (Late 2016-2017) Heat Sink Brackets
Replace the metal spring brackets that press the heat sink against the CPU.
MacBook Pro 15" Retina (Mid 2015) Upper Case Assembly
Replace an upper case assembly compatible with the Mid 2015 MacBook Pro 15" Retina laptop.
Device Info
In June 2012 Apple released the MacBook Pro 15" with a new Retina display with a 2880-by-1800 resolution. The Retina display models that followed the 2012 model vary by specifications and features.
The most common repairs with the 15" MacBook Pro with Retina Display laptops are replacing a dead battery or a damaged display assembly. Choose a model for more specific information.
The MacBook Pro 15" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Retina Display repair guides for step-by-step instructions on how to make the fix.
