MacBook Pro 15" Retina Mid 2014 Dual Graphics Logic Boards
Grab a toolkit for your MacBook Pro 15" Retina Mid 2014 Dual Graphics model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Parts that work with MacBook Pro 15" Retina Mid 2014 Dual Graphics:
MacBook Pro 15" Retina (Mid 2014, Dual Graphics) 2.5 GHz Logic Board
Replace a 2.5 GHz Core i7 logic board (motherboard) compatible with the mid 2014 Dual Graphics model MacBook Pro 15" Retina laptop. Included Ports: 2 Thunderbolt (Mini Di...
MacBook Pro 15" Retina (Late 2013, Dual Graphics) 2.3 GHz Logic Board
Replace a 2.3 GHz Core i7 logic board (motherboard) compatible with the Late 2013 Dual Graphics model MacBook Pro 15" Retina laptop. Included Ports: 2 Thunderbolt (Mini D...
MacBook Pro 15" Retina (Late 2013, Dual Graphics) 2.6 GHz Logic Board
Replace a 2.6 GHz Core i7 logic board (motherboard) compatible with the Late 2013 Dual Graphics model MacBook Pro 15" Retina laptop. Included Ports: 2 Thunderbolt (Mini D...
MacBook Pro 15" Retina (Mid 2014, Dual Graphics) 2.8 GHz Logic Board
Replace a 2.8 GHz Core i7 logic board (motherboard) compatible with the Mid 2014 Dual Graphics model MacBook Pro 15" Retina laptop. Fix processing issues like unexpected ...
Device Info
On July 29, 2014 Apple introduced a new 15" MacBook Pro with Retina display that is externally identical to the "Late 2013" model by dimensions, weight, and 2880x1800 display resolution. Internally, the Mid 2014 Dual Graphics (DG) model has faster processors and two graphics processors: an Iris Pro 5200 and a NVIDIA GeForce GT 750M graphics processor. The Mid 2014 model has two USB 3.0 ports, an HDMI port, an SDXC card slot, a MagSafe 2 port, two Thunderbolt 2 ports, Bluetooth 4.0, and 802.11ac Wi-Fi. Like the Early 2013 and Late 2013 models the Mid 2014 does not have Ethernet or Firewire ports, although adapters are available.
The most common repairs with the 15" MacBook Pro Retina Mid 2014 laptops are replacing a dead battery, replacing a malfunctioning left or right fan, or a damaged display assembly.
The battery in a MacBook Pro 15" Retina Mid 2014 is adhered to the inside of the upper case. Our battery repair kits include the needed adhesive.
The MacBook Pro 15" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Retina Display Mid 2014 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 15" Retina Display Mid 2014 earned a 1 out of 10 in iFixit's repairability assessment.
