MacBook Pro 15" Model A1211 Display Components
Grab a toolkit for your MacBook Pro 15" Model A1211 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Parts that work with MacBook Pro 15" Model A1211:
MacBook Pro 15" (Models A1150/A1211) Display Data Cable
A damaged display data cable can cause video defects
MacBook Pro 15" (Models A1150/A1211) Display Inverter
A bad inverter board can cause a dead backlight
MacBook Pro 15" (Models A1150/A1211) Rear Display Bezel
Replace a damaged bezel without the cost of a new LCD
MacBook Pro 15" (Models A1211/A1226) Airport Antenna Cables
Replace the antenna cables and the assembly that rests inside the antenna cover compatible with the A1211 or A1226 model 15 inch MacBook Pro laptop.
MacBook Pro 15" (Models A1211/A1226/A1260) Antenna Cover
Replace an antenna cover that houses the AirPort antenna cable assembly within the clutch cover compatible with the model A1211, A1226, A1260 15 inch MacBook Pro laptop.
Device Info
The model A1211 15" MacBook Pro features a switch to the faster Core 2 Duo processor and the addition of a Firewire 800 port.
The most common repairs with the model A1211 15" MacBook Pro are replacing a dead battery, replacing a malfunctioning left or right fan, and upgrading the hard drive or RAM. The MacBook Pro 15" Model A1211 Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 4 GB of RAM. In addition, you can install a 8x SuperDrive for faster burning speeds.
Once you've bought your parts and tools, check out iFixit's A1211 MacBook Pro 15" repair guides for step-by-step instructions on how to make the fix.
