Click Image To Zoom
Required Tools
Add All Tools to Cart »Replacement Guides
MacBook Pro 13" Unibody Early 2011
Difficulty: Moderate
MacBook Pro 13" Unibody Late 2011
Difficulty: Easy
MacBook Pro 13" Unibody Mid 2009
Difficulty: Easy
MacBook Pro 13" Unibody Mid 2010
Difficulty: Easy
MacBook Pro 13" Unibody Mid 2012
Difficulty: Easy
Compatibility
| MacBook Pro 13" Unibody Early 2011 |
| MacBook Pro 13" Unibody Late 2011 |
| MacBook Pro 13" Unibody Mid 2009 |
| MacBook Pro 13" Unibody Mid 2010 |
| MacBook Pro 13" Unibody Mid 2012 |
Stories
My Problem
My Mac's battery monitor had been telling me for some time I needed to replace the battery, and it was getting where a charge would last less than an hour.
My Fix
The step-by-step instructions were simple and could not have been easier to follow. To summarize, you remove the screws holding the back cover in place, disconnect the battery, remove two weird screws holding the battery down, replace the battery and put all the screws back in. Took me about five minutes, and that was with my taking extra time in case something was more complicated than it looked.
My Advice
The two screws holding down the battery have some kind of weird y-shaped slot in the head instead of the standard Phillips or Torx heads. I didn't have a driver that fit it, but was able to use a small slotted screwdriver to catch one of the Y slots and just apply lots of downward pressure to the screw head while rotating it back out. Worked fine for me.
My Problem
The symptom: Touchpad stopped clicking in.
The troubleshooting: I took the bottom off the Macbook Pro Mid 2010 and removed the battery to figure out why the touchpad wasn't working. Adjusted the click screw underneath the touchpad and put the battery back in. The touchpad wouldn't click. So I removed the battery once more. The touchpad clicked down when the battery was removed. Looked closely at the battery and noticed that it had started buldging. BAD NEWS.
My Fix
Received the battery quicker than I thought I would. Thanks iFixit for the fast shipping. I had been using the Macbook for a few days without the battery by just plugging it into power when I needed it and setting it up to hibernate when I closed the lid or pushed the power button. I removed the bottom and installed the new battery. Buttoned everything up and sure enough. The touchpad was clicky again. Booted up the Macbook and checked my battery health monitor app that I had installed months ago. The battery had more MAh than the original max MAh for that model Macbook. Causing the battery health to jump up to 106%.
My Advice
Always use OEM parts for battery replacements. Never misjudge a non-clicky touchpad on an otherwise perfectly working Macbook as just a touchpad issue. Things aren't always as they seem.
My Problem
The issue was that after nearly five years of continuous use, the MacBook's lithium battery was failing and the ominous "Replace Soon" label began to appear under the battery icon.
My Fix
At first, the original battery sent didn't work out as well as expected. However, iFixit's support team quickly remedied the situation with issuing a new replacement through the same fast FedEx channel as the original one. And, the second repair was just as fast as before.
My Advice
Batteries seem to be funny things and therefore, I think it is important to thoroughly test the battery that you received to make sure it is performing optimally. The repair itself is a piece of cake, just follow the guide on the website.
My Problem
I needed to replace my battery
My Fix
very well
My Advice
nothing to complain about it
My Problem
I've got an 2012 older MacBook Pro with an aging battery that eventually kind of exploded on itself and stopped working!
My Fix
Repair was easy: step by step instructions, a couple screws/plugs - BOOM - all set!
My Advice
This is actually my second battery - first OEM battery from iFixit so assuming the battery quality is solid, I will be back!
My Problem
No battery in my MacBook Pro.
My Fix
The repair was easy.
My Advice
Get the battery replaced ASAP. It runs way better now!
My Problem
Old battery died
My Fix
Very quick and easy
My Advice
Works as expected
My Problem
I replaced batteries for my sisters before they would turn back to school and out of town. Their batteries were done and they all had to have their MacBook plugged in all the time, but not anymore! :)
My Fix
The repair was very easy and it didn't take long either. There have been absolutely no problems with the new batteries and they all came well packaged. The repair was really fun and it was even more fun to see my sisters happy faces after :)
My Advice
Don't forget to have a tri-wing screwdriver before you begin, there is no other way to take out the battery. And I highly suggest to not rush things and one should not be tired while repairing :)
My Problem
Battery was rapidly losing charge.
My Fix
I ordered the battery from ifixit, used my Pro Tech Tool Kit, followed the step-by-step instructions on the ifixit website and now my MacBook Pro is back on track. Very straight forward - even for a novice like myself.
My Advice
Watch the video, read the instructions; ensure a clean work surface, plenty of light; lay out all required tools and above all, take your time.
My Problem
My Mac had been saying to service the battery for about 3 years, so it was about time...
My Fix
It's a very straightforward repair.
My Advice
No
Related Questions
3 Answers 0 Score |
Can I replace the battery with 10-hours battery of the new MacBook? |
4 Answers 0 Score |
Possible to replace battery? |
7 Answers 3 Score |
My computer don't recognize my new battery |
1 Answer 0 Score |
I need a batterie, what is the correct that I nedd? |
3 Answers 1 Score |
Battery model number MacBook Pro 13 inch 2010 |
