MacBook Pro 13" Unibody (Early 2011/Late 2011/Mid 2012) Airport/Bluetooth Cable
  • MacBook Pro 13" Unibody (Early 2011/Late 2011/Mid 2012) Airport/Bluetooth Cable
Condition: Used
$24.99
$24.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Is your computer having communication problems?
This cable connects the wireless board to the logic board. Identified by 821-1312-02 printed on the cable.
Repair Stories
User avatar
My Problem
Wifi and Bluetooth wouldn't want to work. Could really figure out why and then read the problem descriptions here that 100% matched mine.
My Fix
No problems whatsoever. Just did the steps, worked like a charm!
My Advice
No advice, no! Just follow the guide and you'll be fine.
User avatar
My Problem
My wifi wasn't working on my mid 2012 MacBook Pro. I first decided to replace the actual Airport card but my wifi still wasn't working. So I called Ifixit and they said to try replacing just the cord instead. I did that, and I have not had any problems since. I also got my money back for the airport . . .
User avatar
My Problem
I was a wifi no hardware installed error and lost my bluetooth capability
My Fix
The repair was super easy with the aid of ifixit tool kit. The cable was all that's needed to fix the problem. I'm glad that I did not over react by purchasing a new wifi card as well.
thank you for sharing other people's expe . . .
User avatar
My Problem
My laptop began not connecting to WIFI or losing the connection and not reconnecting. Eventually I noticed the dreaded "WIFI hardware not found" message.
My Fix
I looked online until I stumbled across this part and the comments. Most people were saying how replacing this cable fixed their problem. I can hap . . .
User avatar
My Problem
I was having issues with my Wifi Dropping a lot. After researching I found out that there was an issue with the Airport/Bluetooth Cable.... so rather then paying Apple to diagnose that I needed a new Airport/Bluetooth Cable and charge me an arm and a leg to repair it... i figure I would try this ou . . .
User avatar
My Problem
My computer randomly started telling me there was no wifi hardware installed, and while it would often fix itself if I restarted the computer, after a while the problem persisted. I tried resetting the SMC/PRAM, reinstalling the software, downloading programs, all that great stuff before I concluded . . .
User avatar
My Problem
My airport/bluetooth card blew in my MacBook Pro, and I needed a replacement ASAP. Mac doesn't sell their parts without the install and I have IT that does it here, so I just needed the parts.
My Fix
Perfectly.
My Advice
Don't buy Apple ;-p
User avatar
My Problem
Little buy little i began to loose airport connection, tried every software issues, plist, etc.. Then message "no hardware found remained.
My Fix
Changed the wifi device, no use, before bringing it to a repair shop i ordered an airport bluetooth cable, changed it and it works fine.
My Advice
Should have began with th . . .
User avatar
My Problem
After replacing my macbook pro hard drive with an ssd one my airport/bluetooth failed on my computer. Probably because I broke something internally when I took it apart in the first place. No amount of software changes or restarts fixed it.
My Fix
Easy as.
I bought each component - helps that fixit supply . . .
Show more
