MacBook Pro 13" Retina (Late 2012/Early 2013) Battery
  • MacBook Pro 13" Retina (Late 2012/Early 2013) Battery / New / Fix Kit
  • MacBook Pro 13" Retina (Late 2012/Early 2013) Battery / New / Part Only
  • 360°
360
New battery guaranteed at capacity greater than 6270 mAh.
$89.99
$89.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
If you're experiencing bad battery life, we've got everything you need to replace it! These batteries are well adhered to the upper case of the computer so removing them isn't as straightforward as we'd like it to be. Fear not! Our kit offers all the tools needed to perform the repair and our guide shows you how to use the kit.
Part Assembly includes:
  • Installation adhesive
Fix Kit contents:
MacBook Pro Retina batteries are originally adhered to the upper case assembly as a single part from Apple. The parts we sell may have been separated from this assembly. Consequently, the battery adhesive may have some cosmetic flaws.
Note: Lithium ion battery shipping regulations limit the shipping methods for orders containing batteries. Domestic orders may only be shipped via Standard shipping. iFixit is not able to ship batteries internationally or outside the contiguous US at this time. iFixit Customer Support will contact you if your order needs to be modified after it is placed.
Design Capacity: 6600 mAh
Repair Stories
User avatar
My Problem
My wife has had her Macbook for a long while now and as with all batteries, over time, it has lost some of it's capacity. I trusted iFixit's kit and community of experts, along with repair guides to replace the battery myself.
My Fix
Following the guide to a T, I was able to get everything taken out and rep . . .
User avatar
My Problem
Battery was getting old and not performing well. Its 6 years old and would shut down at 50%.
My Fix
Great! Done in 30 minutes.
My Advice
Reset your Mac's SMC. Try doing that first, but make sure you do it with the new battery, once installed.
User avatar
My Problem
Battery had been dead for over 1 year. Laptop was tethered to the power cord in my living room. Finally deduced to set it free!
My Fix
Very straight forward. The iFixit Repair Guide was spot on. I took my time being very methodical and it still only took me about 1.25 hours. Anybody can do this with pa . . .
User avatar
My Problem
My battery was shot, and would die at 50%.
My Fix
Repair was fairly simple, and the new battery I got from ifixit was very easy to install once the old one was out. Now my Mac works great, and has normal battery life!
My Advice
The hardest part is the adhesive on the lower battery packs. I used a razor blade pushed un . . .
User avatar
My Problem
Replaced defective battery.
My Fix
Easy pezzy. Instructions and tools in the kit were great. The most difficult part was waiting for the glue dissolver to do it's magic.
My Advice
One thing to note: the back case screws on the beveled edges go in at an angle, not straight down. I slightly stripped the treads one one h . . .
User avatar
My Problem
Defective battery - no charge / no power without AC plugged in.
My Fix
Much quicker than in the guide - used an infinitesimally small fraction of the solvent provided (maybe 2ml per side) and the glue softened immediately. Used alcohol cleaning pads to remove the residue.
My Advice
Use a tiny, tiny amount of the sol . . .
User avatar
My Problem
The battery was getting old and was not holding its charge like it used to.
My Fix
The repair went fine the guide is comprehensive. My Mac was restored to how it was years ago overall very happy
My Advice
1) KEEP TRACK OF SCREWS
2)stripping the screws for the battery is almost too easy be careful
User avatar
My Problem
Battery needed to be replaced
My Fix
everything went smoothly, prying off the old batteries was the only moderate task. everything else was easy.
My Advice
I pried off the batteries the the plastic back cover of a mifi device so i was able to have a stable chimmy. worked a lot easier without the fear of puncturing the . . .
User avatar
My Problem
My computer was shutting down at 60% indicated battery strength.
My Fix
The instructions were near perfect! I was quite apprehensive about tackling this job but the fixit kit was very complete and of good quality. Good job you guys!
My Advice
Be patient and follow the instructions without deviation!
User avatar
My Problem
Battery shutting computer down before discharged - 5 years old
My Fix
Great! Guide made it simple. Just follow it step by step.
My Advice
Lay your computer on a white towel so you can find any screws you drop. Put a piece of Packaging Tape upside down and stick your screws to it so they are easy to find. You can a . . .
Show more
