MacBook Pro 13" Unibody Case Components
Grab a toolkit for your MacBook Pro 13" Unibody model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Choose your model of MacBook Pro 13" Unibody:
Parts that work with MacBook Pro 13" Unibody:
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad
Replace a scratched or malfunctioning trackpad in your Mid 2009 to Mid 2012 13” Unibody MacBook Pro model A1278 laptop. Part #922-9063, 922-9525, 922-9773.
MacBook Pro 13" Unibody (Early 2011-Mid 2012) Airport/Bluetooth Bracket
Replace the bracket that houses the Airport/Bluetooth board compatible with the Early 2011 to Mid 2012 A1278 Unibody 13 inch MacBook Pro laptop. Part #076-1381.
MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Upper Case
Replace an upper case assembly compatible with the model A1278 Mid 2009 to Mid 2010 MacBook Pro 13" Unibody laptop. Includes the aluminum upper case frame, keyboard, batt...
MacBook Pro 13" Unibody Lower Case
Replace a scratched or bent lower case panel on your laptop.
MacBook Pro 13" Unibody (Early 2011-Mid 2012) Upper Case
Replace an upper case assembly compatible with the model A1278 Early 2011 to Mid 2012 MacBook Pro 13 inch Unibody laptop.
MacBook Pro Unibody (Mid 2009-Mid 2012) Trackpad Mounting Screws
Replacement screws and springs for mounting the trackpad in the upper case assembly of your mid 2009 to mid 2012 13" and 15" MacBook Pro Unibody laptop.
Device Info
With the Mid 2009 model 13 inch MacBook Pro Unibody laptop, Apple brought back the Firewire 800 port, and added an SD card slot. The 13" Unibody models continued through Mid 2012.
The most common repairs with the MacBook Pro 13" Unibody models are replacing a dead battery or upgrading the hard drive or RAM. Choose a model for more specific information.
The MacBook Pro 13" Unibody models require a Tri-point Y0 Screwdriver to remove the battery. The battery kit includes all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Unibody repair guides for step-by-step instructions on how to make the fix.
