MacBook Pro 13" Two Thunderbolt Ports Late 2020 Heat Sinks
Grab a toolkit for your MacBook Pro 13" Two Thunderbolt Ports Late 2020 model A2338 and fix a broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Parts that work with MacBook Pro 13" Two Thunderbolt Ports Late 2020:
MacBook Pro 13" (A2338, Late 2020) Heat Sink
Replace a damaged heat sink compatible with a late 2020 model A2338 13" MacBook Pro with Two Thunderbolt Ports. The heat sink dissipates heat from the CPU.
MacBook Air 13" and MacBook Pro 13" (A2337, A2338, Late 2020) Heat Sink Brackets
Replace the two metal spring brackets that press the heat sink against the CPU in a late 2020 model A2337 or A2338 13" MacBook Air or MacBook Pro laptop.
Device Info
Released in Late 2020, this 13" Macbook Pro features Apple's M1 3.2 GHz 8-core CPU, 16-core Neural Engine processors. Model A2338.
The most common repairs with the 13" Late 2020 model MacBook Pro 13" with Two Thunderbolt Ports laptops are replacing a dead battery or a damaged display assembly.
The battery is adhered to the inside of the upper case. Our batteries include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Late 2020 repair guides for step-by-step instructions on how to make the fix.
