Parts Mac MacBook Pro 13" Touch Bar 2019 SSD Enclosures
Store
Don't know your model? ID Your Mac
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
$7.99
MacBook Pro 13" Retina (Late 2016-2019) Display Assembly / A-Stock / Silver
The display assembly includes the Retina LCD screen, display cover, bezel, FaceTime HD Camera, clutch hinges, display daughter board, and cable spring mechanism. Compatib...
From $469.99
MacBook Pro 13" Retina (Late 2016-2019) Trackpad / New / Silver
Replace a scratched or malfunctioning trackpad compatible with a Late 2016 to 2019 MacBook Pro 13" with Retina Display, Touch Bar or Function Keys model.
From $49.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Antenna Bar
Replace a damaged or malfunctioning antenna.
From $24.99
MacBook Pro Retina (A1989 & A1990 Mid 2018-2019) USB-C Board
Replace one of the thunderbolt connector boards from the left or right side of your laptop.
$34.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Lower Case Screw Set / Silver
Replace the external screws securing the lower case.
$19.99
MacBook Pro 13" Retina (Mid 2018-2019) Display Cable
Replace the short flex cable that connects the display daughter board to the logic board.
$24.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Lower Case / Silver / New
Replace a scratched or dented lower case compatible with a 2016 to 2019 model 13" MacBook Pro with Retina Display and Touch Bar.
From $29.99
MacBook Pro 13" Retina (Late 2016-2019) Heat Sink Brackets
Replace the two metal spring brackets that press the heat sink against the CPU in a 2016 to 2019 model 13" MacBook Pro with Retina Display.
$5.99
Showing products 1 - 10 of 31
Device Info
Introduced in May 2019, this 13" Macbook Pro features Coffee Lake processors up to 2.8 GHz Core i7 with Turbo Boost up to 4.7 GHz. Model A1989.
The most common repairs with the 13" 2019 model MacBook Pro with Retina Display and Touch Bar laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina and Touch Bar 2019 is adhered to the inside of the upper case. Our batteries include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display and Touch Bar 2019 repair guides for step-by-step instructions on how to make the fix.
