MacBook Pro 13" Retina Heat Sinks
Grab a toolkit for your MacBook Pro 13" Retina model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Choose your model of MacBook Pro 13" Retina:
Parts that work with MacBook Pro 13" Retina:
MacBook Pro 13" Retina (Late 2012-Early 2013) Heat Sink
This part attaches to the processor and helps dissipate heat.
MacBook Pro 13" Retina Fan Ducts
Replace the elastic gaskets that direct the airflow from the fans to the heat sink compatible with the A1425 model Retina 13 inch MacBook Pro laptop. Part #923-0228.
MacBook Pro 13" Retina (Late 2013-Early 2015) Heat Sink
Replace a damaged heat sink. This part dissipates heat generated by your computer's processors.
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Heat Sink
Replace a damaged heat sink compatible with a 2016 to 2019 model 13" MacBook Pro with Retina Display and Touch Bar. The heat sink dissipates heat from the CPU.
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Heat Sink
Replace a damaged heat sink in a 2016 or 2017 model 13" MacBook Pro with Retina Display and function keys.
MacBook Pro 13" Retina (Late 2016-2020) Heat Sink Brackets
Replace the two metal spring brackets that press the heat sink against the CPU in a 2016 to 2020 model 13" MacBook Pro with Retina Display.
MacBook Pro 13" (A2251, 2020) Heat Sink
Replace a damaged heat sink compatible with a 2020 model A2251 13" MacBook Pro laptop. The heat sink dissipates heat from the CPU.
MacBook Pro 13" (A2289, 2020) Heat Sink
Replace a damaged heat sink compatible with a 2020 model A2289 13" MacBook Pro with two Thunderbolt Ports. The heat sink dissipates heat from the CPU.
MacBook Pro 13" (A2159, 2019) Heat Sink
Replace a damaged heat sink compatible with a 2019 model A2159 13" MacBook Pro with two Thunderbolt ports. The heat sink dissipates heat from the CPU.
MacBook Pro 13" (A2338, Late 2020) Heat Sink
Replace a damaged heat sink compatible with a late 2020 model A2338 13" MacBook Pro with Two Thunderbolt Ports. The heat sink dissipates heat from the CPU.
Device Info
Late in 2012 Apple released the MacBook Pro 13" with a new Retina display having 2560-by-1600 resolution. The Retina Display models that followed the 2012 model vary by specifications and features.
The most common repairs with the 13" MacBook Pro with Retina Display laptops are replacing a dead battery or a damaged display assembly. Choose a model for more specific information.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display repair guides for step-by-step instructions on how to make the fix.
