Parts Mac MacBook Pro 13" Retina Early 2015 Headphone Jacks
Store
Don't know your model? ID Your Mac
MacBook Pro Retina (A1425, A1502, and A1398) Plastic Feet / Part Only
Replace missing or damaged black plastic feet on your laptop's lower case.
From $4.99
MacBook Pro 13" Retina (Early 2015) Battery / New / Fix Kit
Replacement 6560 mAh battery compatible with a MacBook Pro 13" Retina (Early 2015) laptop.
From $99.99
MacBook Pro 13" Retina (Early 2015) Trackpad Cable
Replace the flex cable that connects the trackpad to the logic board.
$9.99
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
$7.99
OWC Aura Pro X2 SSD
OWC Aura Pro X2 SSD
Replace or upgrade the PCIe solid-state drive in a variety of Macs.
From $149.99
MacBook Pro Retina (2012-2015) Lower Case Screw Set / Part Only
Replace a stripped or missing screw securing the lower case.
From $19.99
MacBook Pro Retina (2012-2015) Display LVDS Cable
Replace a damaged connector or torn LVDS display cable.
$19.99
MacBook Pro 13" Retina (Late 2013-Early 2015) MagSafe 2 DC-In Board
Replace a broken or damaged MagSafe 2 DC-in board for your Late 2013 to Early 2015 MacBook Pro 13" Retina laptop with this part. This part connects wall adapter power to ...
From $20.99
MacBook Pro 13" Retina (Late 2013-Early 2015) Right Speaker
Replace a broken or damaged right speaker for your Late 2013 to Early 2015 MacBook Pro 13" Retina laptop with this part and fix sound issues.
$29.99
Showing products 1 - 10 of 33
Device Info
In March 29, 2015 Apple introduced a new 13" MacBook Pro with Retina Display. Externally, this "Early 2015" model looks very much like the "Late 2013" and "Mid 2014" models. The 13.3" widescreen 2560x1600 (227 ppi) display, external ports, and Wi-Fi capabilities are unchanged. The Early 2015 model has two USB 3.0 ports, an HDMI port, an SDXC card slot, a MagSafe 2 port, two Thunderbolt 2 ports, Bluetooth 4.0, and 802.11ac Wi-Fi. Like the 2013 and 2014 models, this machine has no Ethernet or Firewire ports, although adapters are available. This model introduces Apple's "Force Touch" trackpad, has an estimated 10 to 12 hours of battery life, more advanced processors, and faster integrated RAM.
The most common repairs with the 13" Early 2015 model MacBook Pro with Retina Display laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina Early 2015 is adhered to the inside of the upper case. Our battery repair kits include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display Early 2015 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 13" Retina Display Early 2015 earned a 1 out of 10 in iFixit's repairability assessment. Watch the Teardown Review for more:
