MacBook Pro 13" Four Thunderbolt Ports 2020 Logic Boards
Grab a toolkit for your MacBook Pro 13" Four Thunderbolt Ports 2020 model A2251 and fix a broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Parts that work with MacBook Pro 13" Four Thunderbolt Ports 2020:
MacBook Pro 13" (A2251, 2020) 2.0 GHz Logic Board with Paired Touch ID Sensor
Replace a damaged or malfunctioning 2.0 GHz Core i5 Motherboard. The Touch ID sensor is paired to the logic board and is included.
MacBook Pro 13" (A2251, 2020) 2.3 GHz Logic Board with Paired Touch ID Sensor
Replace a damaged or malfunctioning 2.3 GHz Core i7 Motherboard. The Touch ID sensor is paired to the logic board and is included.
Device Info
Released in 2020, this 13" Macbook Pro features Quad-core Intel Core i5 or i7 processors. Model A2251.
The most common repairs with the 13" 2020 model MacBook Pro 13" with Four Thunderbolt Ports laptops are replacing a dead battery or a damaged display assembly.
The battery is adhered to the inside of the upper case. Our batteries include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display and Touch Bar 2019 repair guides for step-by-step instructions on how to make the fix.
