MacBook Core Duo/Santa Rosa/Penryn LCD Mounts
  • MacBook Core Duo/Santa Rosa/Penryn LCD Mounts
Condition: Used
$7.99
$7.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
LCD hanging on by a thread?
Lock it down with some LCD mounts! Includes LCD mounts and airport antenna cables.
This part works with model A1181 MacBooks with 2 antenna connectors. If your MacBook has 3 antenna connectors you need the Core 2 Duo hinge mounts.
Compatibility
MacBook Core 2 Duo
2 GHz (Early 2009)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz
2 GHz
Repair Stories
User avatar
My Problem
WIFI antenna wire was broken where it passes through the hinge of the display.
My Fix
The online guide was helpful - take the time to go slow and follow each step.
My Advice
Set aside enough time to do the repair right - keep track of where the screws from each step go so you don't get them mixed up later.
User avatar
My Problem
My airport would only work if the computer did not move after startup. If moved the airport would turn off and could not be turned back on without restarting. After researching the problem I deduced that it was probable that the antenna wires had been pinched/worn from the screen opening and closing . . .
