MacBook Air (Late 2008-Mid 2009) 120 GB Hard Drive
  • MacBook Air (Late 2008-Mid 2009) 120 GB Hard Drive
  • MacBook Air (Late 2008-Mid 2009) 120 GB Hard Drive / Without Padding
$89.99
$89.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Replace the 120 GB hard drive in your Late 2008/Mid 2009 with this part.
Note
Drive uses zif-type connector. Does not include hard drive cable.
Note
This drive works only in Late 2008 or Mid 2009 MacBook Airs. Original versions of the MacBook Air use a different connector configuration and are therefore incompatible.
Compatibility
MacBook Air Models A1237 and A1304
1.6 GHz (Late 2008)
1.86 GHz (Late 2008)
1.86 GHz (Mid 2009)
2.13 GHz (Mid 2009)
Repair Stories
William Vaughan's Story Photo #1168254
William Vaughan's Story Photo #1168256
William Vaughan's Story Photo #1168257
My Problem
This is my fairly new Dell XPS 13 (9360), 7 months old. The battery stopped working so I ordered a new one to replace it.
My Fix
Disassembly / reassembly as specified in the IFIXIT article worked exactly as specified. I removed the original battery, opened up the package I had ordered with the new battery, . . .
John Joslin's Story Photo #1334073
My Problem
No power, dead battery, etc.
My Fix
I decided to do a couple of other errands since I was going to be in the area :) .... so I replaced the Fan ( ...still good but 9 years old ! ) , Subwoofer/Right Speaker, & the Left Speaker ( BOTH speakers bad ; buzzy, garbled sound ...) , as well as the defective MagSaf . . .
My Problem
I broken the display.
My Fix
With your help very early.
My Advice
How long do i have warranty?
My Problem
Had to change micro SD card slot in Nintendo switch. Super glue got into it.
My Fix
Good
My Advice
Don’t use super glue near a nintendo switch.
My Problem
The battery died from age and repeated charges.
My Fix
I was able to remove the battery without difficulty after carefully following all the steps listed--and will all the recommended tools I purchased from ifixit. Now I'm just waiting on my new watch battery to arrive from an outside vendor, so that I can . . .
My Problem
Dead swollen battery & slow memory
My Fix
Pretty Smooth some of the screws were hard to loosen up.
My Advice
I was at first affraid of opening the computer to make the repairs & put it off for years . I wish I had done it sooner.
My Problem
My optical drive had failed sometime in the past. I rarely used it. Recently I was doing upgrades to other components and decided to replace the Superdrive.
My Fix
The repair went very well. I was surprised when the internals of my MacBook did not quite match the repair guide. I had to rely on some per . . .
My Problem
Battery expired
My Fix
Video made it easy along with the tools I purchased
My Advice
I would just say that whomever is considering doing this buy the tools. They are a few bucks but made this job simple.
My Problem
Tried to remove battery to replace original that was not holding a charge very long
My Fix
The blue pry tools got the chassis opened, with a little effort to get the front/back separated
My Advice
The small locking tabs that hold circuit strips are very small and take no effort to open. Unfortunately for me, the blue . . .
My Problem
My tablet was stuck on bootloop for a few months, and after flashing every stock ROM file I could find, I found that it was the motherboard that was faulty.
My Fix
The repair was easier than I thought, and it took less time than I thought! It was my first time repairing hardware so it was really exciting to . . .
Show more
