Parts Mac MacBook Air MacBook Air 13" MacBook Air 13" Late 2020 Case Components
Store
Grab a toolkit for your MacBook Air 13" Late 2020 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Don't know your model? ID Your Mac
MacBook Air 13" (Late 2020) Trackpad / New / Dark Gray
Replace a trackpad compatible with an Late 2020 MacBook Air 13" laptop model A2337.
$79.99
MacBook Air 13" (A2337, Late 2020) Lower Case / New / Silver
Replace a scratched or dented lower case for a Late 2020 model A2337 13" MacBook Air.
From $89.99
MacBook Air 13" (Late 2018-Late 2020) Display Cable Bracket
Replace a bent or missing metal bracket securing the display cable connector to the display daughter board in a late 2018 to late 2020 model 13" MacBook Air.
From $0.99
MacBook Air 13" (Late 2018-Late 2020) USB-C Cable Bracket
Replace a bent or missing bracket that secures the USB-C cable to the logic board in a 2018 to late 2020 model 13" MacBook Air.
From $2.99
MacBook Air 13" (2020) Antenna Bar Cable Bracket / Used
Replace a bent or missing bracket that secures the antenna bar cable compatible with a 2020 Model A2179 or A2337 13 inch MacBook Air laptop.
$7.99
MacBook Air 13" (A2337, Late 2020) Upper Case with Keyboard / New / Gold
Replace an upper case and keyboard compatible with a late 2020 model A2337 MacBook Air 13 inch laptop. Includes the keyboard and palm rest area.
$299.99
MacBook Air 13" (A2337, Late 2020) 8-Core 3.2 GHz CPU 7-Core GPU Logic Board with Paired Touch ID Sensor / 8 GB / 256 GB
Replace a damaged or malfunctioning 8-Core 3.2 GHz M1 CPU 7-Core GPU Motherboard for a late 2020 model A2337 13" MacBook Air. The Touch ID sensor is paired to the logic b...
From $499.99
MacBook Air 13" and MacBook Pro 13" (A2337, A2338, Late 2020) Heat Sink Brackets
Replace the two metal spring brackets that press the heat sink against the CPU in a late 2020 model A2337 or A2338 13" MacBook Air or MacBook Pro laptop.
$9.99
MacBook Air 13" (A2337, Late 2020) Trackpad Cable Bracket
Replace a bracket that secures the trackpad cable to the logic board compatible with the late 2020 model A2337 13" MacBook Air laptop.
$24.99
MacBook Air 13" (A2337, Late 2020) Audio Daughterboard Cable Bracket
Replace a bracket that secures the audio daughter board cable to the logic board compatible with the late 2020 model A2337 13" MacBook Air laptop.
$9.99
Showing products 1 - 10 of 10
Device Info
This refresh of the Retina MacBook Air has a new model number, A2337, and has the EMC number 3598. This model features Apple’s new M1 chip, marking the start of their transition away from Intel-based systems.
Introduced in November 2020 this model is equipped with two Thunderbolt 3 ports. Internally it features a 13.3 inch display with native 2560 x 1600 pixel resolution.
