Parts Mac MacBook Air 13" Late 2010 SSD Enclosures
Store
Don't know your model? ID Your Mac
MacBook Air 13" (Late 2010-2017) Replacement Battery / Fix Kit
An aftermarket replacement battery compatible with a MacBook Air 13" laptop.
From $79.99
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
$7.99
Apple MagSafe 1 AC Adapter / 85 W / AC Adapter End / New
Replace a broken or damaged Apple MagSage 1 AC adapter with this part.
From $39.99
Silicone 2.5" Hard Drive Enclosure with USB 2.0 Cable
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part.
$9.99
MacBook Air 13" (Late 2010-2017) Lower Case Screw Set
Replace missing screws in the lower case of your laptop. This set is compatible with a Late 2010 to 2017 MacBook Air 13" laptop.
$19.99
MacBook Air 13" (Late 2010-2017) Fan
Replace a defective or noisy fan compatible with a Late 2010 to 2017 MacBook Air 13" laptop with this part.
From $6.99
MacBook Air Plastic Feet
Replace the black plastic feet on the lower case of your laptop. These feet are compatible with most 11" or 13" MacBook Air laptops.
Universal Drive Adapter
Turn your current hard drive into an external drive with this part.
$24.99
MacBook Air 13" (Late 2010-Mid 2011) Display Assembly
Replace your cracked, dark, or dead-pixel infested display assembly. This 1440x900 LCD, 13.3" screen is compatible with 1.86 or 2.13 GHz (Late 2010) 13" MacBook Airs and ...
From $149.99
Showing products 1 - 10 of 31
Device Info
In October of 2010, Apple introduced a total redesign of the MacBook Air 13". The new Air features a flash memory module instead of a conventional hard drive, and the battery dominates most of the internal space. This lack of conventional hard drive allows the machine to be insanely thin.
Select your category below or browse all compatible parts to find what you need to fix your laptop!
