Parts Mac MacBook Air 13" Early 2014 Hard Drives (SATA)
Store
Don't know your model? ID Your Mac
MacBook Air 13" (Late 2010-2017) Replacement Battery / Fix Kit
An aftermarket replacement battery compatible with a MacBook Air 13" laptop.
From $79.99
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
$7.99
OWC Aura Pro X2 SSD
OWC Aura Pro X2 SSD
Replace or upgrade the PCIe solid-state drive in a variety of Macs.
From $149.99
MacBook Air 13" (Mid 2011-Early 2015) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard compatible with a model A1369 13" MacBook Air from mid 2011 or a model A1466 13" MacBook Air from mid 2012 ...
$19.99
MacBook Air 13" (Mid 2013-2017) I/O Board
Replace a damaged or corroded I/O board for your Mid 2013 to 2017 MacBook Air 13" and fix problems with charging, audio, and data connections. This assembly includes the ...
$79.99
MacBook Air 13" (Mid 2013-2017) Display Assembly
Replace your cracked, dark, or dead-pixel infested display assembly of your MacBook Air. This 1440x900 LCD, 13.3" screen is complete with aluminum case and camera.
From $258.99
MacBook Air 13" (Late 2010-2017) Lower Case Screw Set
Replace missing screws in the lower case of your laptop. This set is compatible with a Late 2010 to 2017 MacBook Air 13" laptop.
$19.99
MacBook Air 13" (Mid 2013-2017) Trackpad Cable
Replace a torn or damaged cable connecting the trackpad to the logic board in a Mid 2013 to 2017 13" MacBook Air.
$14.99
MacBook Air 13" (Late 2010-2017) Fan
Replace a defective or noisy fan compatible with a Late 2010 to 2017 MacBook Air 13" laptop with this part.
From $6.99
Showing products 1 - 10 of 33
Device Info
Released on April 29, 2014, this 13" MacBook Air is much the same as its predecessor externally and internally save for a faster processor and longer reported battery life. Includes one "Thunderbolt" port, two USB 3.0 ports, an SDXC capable SD card slot, 802.11ac Wi-Fi and Bluetooth 4.0.
